Speedometer incorrect lawsuit
Discussion in 'Wheels & Tires' started by rockbug63, Jun 8, 2011.
  1. Jun 27, 2011 at 9:06 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    yup. just gonna get me some larger tires and problem solved.
  2. Jun 27, 2011 at 9:10 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    :facepalm: idiot
  3. Jun 27, 2011 at 9:19 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    this is the second stupid ass lawsuit thread in the past few weeks. WTF get over it and move on.
  4. Jun 27, 2011 at 9:32 AM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    If it's only to extend the warranty to cover what's promised by the manufacturer, whats your problem. If I could get 5k extra warranty I would. Why would you justify a company trying to screw you?
  5. Jun 27, 2011 at 9:38 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    And this is why America is known to be the land of the law suit....
  6. Jun 27, 2011 at 9:40 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    op, you need to find a hobby.
  7. Jun 27, 2011 at 9:41 AM
    oldstick
    oldstick Medicare Member
    GA
    Warranty period does not apply in my case, but yes my 2007 speedometer also reads about 3mph too high compared with GPS or with the roadside radar displays.
  8. Jun 27, 2011 at 9:44 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Getting a good screwing by corporate is the name of the game nowdays...bend over a take it like a man!
  9. Jun 27, 2011 at 9:46 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    dont sweat the petty stuff and dont pet the sweatty stuff
  10. Jun 27, 2011 at 9:47 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    OP, ALL vehicles slightly overestimate the speed from the factory. Just a fact of life.
    Especially motorcycles; they are much worse.
    I think I can understand one point in your original post, and that is that if you have a problem with your truck right at the end of your warranty mileage, you could argue that you actually have slightly less miles than indicated and might be covered.
    I'd say it would have to be a pretty serious problem to even make that worth a fight.
  11. Jun 27, 2011 at 10:00 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    I think that the factory is allowed +/- 5% on speedometer accuracy. That would be +/- 3 mph at 60 mph. I would think that it would be impossible for them to calibrate every vehicle manufactured completely accurate. I agree with everyone here and say "Leave it alone." Don't clog the court system up with frivolous lawsuits. There are more important things that the courts need to decide, like if the McDonald's coffee really is too hot!!! :)
  12. Jul 9, 2011 at 3:01 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Long before this current topic was started, while in for some warranty work, I had them look at this exact problem.
    There is about a 4% to 6% error in indicated speed. Never bothered to check the ODO for accuracy but assumed it would be off also.
    Seeing that this is a common problem, maybe Toyota should extend the warranty distance amount by some fair value. Obviously if you expired the calender time it does not matter.
    The technician said he checked on if the speedometer could be calibrated electronically, his answer was no. I took his word on that and have not worried about it. Does seem odd though since these trucks monitor almost everything.
    Then again, this error may have saved some folks from getting pulled over.
    Or worse yet, from all the Prius braking stuff, if Toyota does have the computer monitoring data, if you were at fault in a collision, that added speed that is indicated may be used against you.
    Very Interesting.
    FWIW, our Ford van is dead on when compared to a Garmin, maybe I'll try the Garmin in the 2010 Corolla and see how that compares.
    PK
  13. Jul 17, 2011 at 2:02 PM
    ILLINOISTACOMAGUY
    ILLINOISTACOMAGUY Well-Known Member
    Darryl
    ILLINOIS
    2005 SR5 SPORT
    WeatherTech Digital floor mats front and rear. Ventvisors, Hood protector, Towing package, Bed tiedowns, Wheel to Wheel steps,
    All I can is WOW
  14. Jul 18, 2011 at 8:22 PM
    shocker01
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    Some of you people seem not to care if you're getting fucked by Toyota. I'm atlaest curious to the fact.
  15. Jul 18, 2011 at 8:37 PM
    #35
    shocker01
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    So your speedo/ odo is dead on. Good for you! I guess some peoples aren't, and c'mon you know you like that taco in your ass.
  16. Jul 18, 2011 at 8:39 PM
    #36
    shocker01
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    Sorry, quote.
  17. Jul 18, 2011 at 9:42 PM
    #37
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    people do bitch about anything and everything. im going to sue because its not a bmw. have yiu guys ever wondered that how can you get a exact reading with a analog display?
  18. Jul 18, 2011 at 9:49 PM
    #38
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I do have something of value to add here on this subject.
    While looking at my ScangagueII I noticed my speedo analog stick on my dashboard is indeed off ~2 MPH, but the truck's computer isn't.
    I was doing 70MPH pegged on it perfectly, and my Scangauge read 68MPH.
    So, to answer some question in here before the shitstorm began, your ODO should be right even tho the dash shows a bit fast.
  19. Jul 18, 2011 at 10:03 PM
    #39
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Since the Taco's powertrain warranty is 60K miles. Winning the lawsuit will get you to... 62K miles. Good luck proving damage or harm, especially since rolling diameters vary so much amongst tires with the same numerical size.
  20. Jul 18, 2011 at 10:08 PM
    #40
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    .... this thread isnt krispy. Its weak sauce.
