Speedometer is off but I wonder why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JayDawg, Apr 29, 2012.
  1. Apr 29, 2012 at 12:37 PM
    JayDawg
    JayDawg [OP] Christian Pastor. Need prayer,have questions? Ask
    Jay
    Sterling, Co. via San Diego, Ca.
    Tacoma 4x4 Access Cab TRD Off Road Package
    4-PIAA 80 Racing Series Off Road Lights, Randy Ellis Design Light Bar, Bilstein 5100 Shocks, Rear Leaf TSB, Mickey Thompson Classic Lock wheels, fog light mod, more to come...
    About a month or so ago, I got pulled over by a local State Trooper for speeding. The speed limit was 65 mph and I had my cruise set at around 68 or 69 mph. He clocked me doing I think it was 73 mph. Since I was going up and down hills, when he clocked me, I thought maybe my truck had just sped up briefly while on cruise. Well, the other day, I was on the freeway and again had the cruise set. The speed limit there was 75 mph and I had my cruise set at 78 mph. However, one of those little road radar sign hit me doing 82 mph. There was road construction ahead and right before the speed limit dropped they had one of those portable machines.
    Now for the life of me, I can't figure out how my speedometer got 4 mph off from what it should be? I know about a year ago I got new rims and tires put on the truck. I however kept the stock tire size. However, the one thing I did change was the rim size. I have a TRD Off Road package 4x4 that came stock with 16" wheels but hear on the aftermarket ones I had to go to a 17" wheel so I did that. I know if you go to a bigger tire size, your speedometer will be off but is it the same thing with rims as well?
    Also, does anyone have a clue how much it will cost me to get my speedometer reset?
    Thanks all.
  2. Apr 29, 2012 at 12:40 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    Bigger is bigger, wheel or tire. What size tire did you wrap around the 17s?
  3. Apr 29, 2012 at 12:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto. What size tire?
    265/70-16 compared to 265/70-17, the 17 is larger by a full inch, and will introduce a speedometer error of 3.3%.
    That might be enough to give you a 78-82 discrepancy... would think it would be closer to 78-80... but those radar signs are not calibrated.
    Should not be enough for a ticket (unless you have out of state plates :D ) if you are sticking to the posted limit.
  4. Apr 29, 2012 at 3:03 PM
    JayDawg
    Jay
    The original tires on my truck were 265/70-16. What is on there now is 265/70 -17. Basically, same size tires as stock but 1" bigger rims.
  5. Apr 29, 2012 at 3:16 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    What they said. If you did indeed go from a 265/70r16 to a 265/70r17 that is a 4% difference in revs/mile. You are reporting about a 5% diference with 4 mph at about 80 mph. What air pressure do you run? Overinflation for the load on the tire will also change the rev/mile numbers, as well as wear down the center of the tread.
    To the best of my knowledge, the speedometer cannot be recalibrated with a simple parameter setting, but there are aftermarket options. For 4 or 5% I would just drive accordingly, but thats me.
    Edit, you posted the tire sizes while I was posting, thats your main factor.
  6. Apr 29, 2012 at 3:18 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    There ya go.
    265/70 reflects the tread width and aspect ratio.
    You have the same tread width and aspect ratio, but those tires are on rims that are 1" larger, therefore, the overall diameter of the tire is 1" larger than stock.
    http://www.tacomaworld.com/forum/tirecalc.php
    Your stock tires were roughly 30.6", your new tires are roughly 31.6"
    To match stock diameter, you would need to go with a 265/65-17.
    But as I said... the 3% error introduced by the larger tires will have a measurable impact on calculated MPG (20.0mpg calculated is actually 20.6mpg), but as for speed, if you hold your indicated speed to the posted limit, it's not going to result in a ticket...
    You're only looking at a 2.12mph error at 65.
    Indicated..............................Actual
    20 mph (32.19 km/h) = 20.65 mph (33.24 km/h)
    25 mph (40.23 km/h) = 25.82 mph (41.55 km/h)
    30 mph (48.28 km/h) = 30.98 mph (49.86 km/h)
    35 mph (56.33 km/h) = 36.14 mph (58.17 km/h)
    40 mph (64.37 km/h) = 41.31 mph (66.48 km/h)
    45 mph (72.42 km/h) = 46.47 mph (74.79 km/h)
    50 mph (80.47 km/h) = 51.63 mph (83.1 km/h)
    55 mph (88.51 km/h) = 56.8 mph (91.41 km/h)
    60 mph (96.56 km/h) = 61.96 mph (99.72 km/h)
    65 mph (104.61 km/h) = 67.12 mph (108.03 km/h)
  7. Apr 29, 2012 at 3:29 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    654 revs/mile on the LT265/70r17 BFG ATs, 680 revs/mile on the P265/70r16 rugged fails, assuming thats what was there, which is a 3.9% change. Diferent brands and tire models vary a bit even for the same size.
  8. Apr 29, 2012 at 3:41 PM
    JayDawg
    Jay
    Cool, thank all for your help. I figured it was due to the larger rims but was unsure. I am now wondering how far off it will be when I put 285/70 r17's on it next? I'll just have to be extra cautious I guess. The State Trooper was also pretty cool when I got pulled over and only gave me a warning so that was a blessing as well.
  9. Apr 29, 2012 at 3:48 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Assuming you pick BFG ATs again, they are 635 rev/mile, so a 7% change from stock. Any other brand will be close.
  10. Apr 29, 2012 at 4:12 PM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    FWIW - If it bugs you, and as mentioned above, there are electronic modules that can be programmed to correct your speedometer calibration. They generally plug inline into the circuit behind the dash.
  11. Apr 29, 2012 at 4:18 PM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
  12. Apr 29, 2012 at 4:37 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yes, there is....
    vvvvvvvvvvvvvvvvvvv
