Speedometer & ODO off?
Discussion in 'Wheels & Tires' started by KevC, Jan 13, 2018.
  1. Jan 13, 2018 at 3:40 PM
    KevC
    KevC [OP] Well-Known Member
    Hi TW,
    I have a quick question. I upsized my tire from 265/65R17 to 265/70R17..
    Since I up-sized my tire I understand that I will actually be going a mile or 2 faster than the listed speedometer.
    Would the larger tire affect my ODO to? If I put 100,000 miles on my tacoma with the upsize tires. If it reads 100k would it mean I actually drove slightly more or slightly less?
    Thanks in advance!
  2. Jan 13, 2018 at 4:40 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    The 265/70/17 are about 99 inches in circumference. The 265/65/17 are about 96 inches. When Your speedometer and odometer thinks you have travelled 96 inches you have actually traveled 99 inches. So if you’re on 265/70/17 tires, and your odometer reads 96,000 mile, your truck has traveled 99,000 miles. The same goes for velocity. If your speedometer reads 96 you are traveling at 99 mph. Reading 32 mph translates to 33 mph. These are approximations.
    KevC[OP] likes this.
  3. Jan 15, 2018 at 7:39 PM
    KevC
    Thanks for the answer.. my OCD self is trying to decide if I should have it re calibrated or ignore it!
  4. Jan 16, 2018 at 10:15 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Compare it to speed over ground with a phone app if possible.
    Factory tolerance for speedo accuracy is +/- 5% from a rolling dyno operator I met. I had to deal with a speeding ticket last year so I took the truck to get the speedometer checked for accuracy specifically with a 265/70/17 tire upgrade.
    Here's a link to my results from the dyno.
    https://www.tacomaworld.com/threads/speedometer-off.435381/#post-12591638
  5. Jan 18, 2018 at 5:10 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    My speedometer, with 285/75/16, is 1 mph off at 65mph
  6. Jan 18, 2018 at 5:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    Check out your speedo/odo against a GPS.
    It's not impossible that the new tires corrected the factory error. Or made it worse.
  7. Jan 18, 2018 at 5:44 PM
    KevC
    I've heard many times on this forum that 265-65-17 to 265-70-17 actually makes the speedometer more accurate.. Can anyone attest?
  8. Jan 18, 2018 at 5:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    See post 6.
    What worked for others may not work for you. Depends on what yours was to begin with.
  9. Jan 18, 2018 at 6:27 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    I have a first gen, but for me, going from 31's to 32's did make my speedo more accurate. It's 1-2 mph off with 31's, but almost dead on with 32's.
  10. Jan 18, 2018 at 9:07 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Depends on how accurate you are from the factory with stock tires, like I said in post 4, factory tolerance is roughly +/- 5%.
    To eliminate confusion in my link, stock OR tire is 265/70/16 so a +1 is a 265/75/16, same diameter as your 265/70/17.
  11. Jan 19, 2018 at 3:14 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
