Speedometer & Odometer stopped working
Discussion in '1st Gen. Tacomas (1995-2004)' started by egeller, Oct 26, 2023.
  1. Oct 26, 2023 at 9:55 PM
    egeller
    egeller [OP] New Member
    I've got a '96 Tacoma Base, and the speedometer and odometer stopped working suddenly. I assume it's a faulty speed sensor. Does that sound right? Does anyone know what might've caused it?
    Thanks
  2. Oct 26, 2023 at 10:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FWIW, as a '96 you have a speedometer cable that runs from the tail housing on the trans to the dash speedo/odo. That cable usually does not fail without making a lot of noise.
