Speedometer off 5 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikkydee, May 9, 2020.
  1. May 11, 2020 at 10:39 AM
    #41
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    That's correct.
    I've never found my ScanGauge to be particularly useful on a regular basis (such as mounting it and looking at it while driving) because it doesn't provide a whole heck of a lot of information. My truck has a manual transmission so it doesn't show a trans temp reading as well.
  2. May 11, 2020 at 10:40 AM
    #42
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I use mine for engine temperature. Saved me once already from overheating on the trail. Truck had hit 240 degrees and the stock gauge hadn't even hit the red yet. I was very thankful that day.
  3. May 11, 2020 at 10:45 AM
    #43
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    My Head Unit is iDataLink compliant so I'm running one of these. I love it. I can display a lot of different gauges (up to 5) tracking a variety of different things. However, since its reading off the OBD2, it displays unmodified MPH so I can't use it for that. My gauge cluster displays my true MPH.
    I just don't like the idea of cutting/splicing stock wiring harnesses. The Hypertech is plug & play. I understand trying to save a few bucks but you may end up spending more fixing a mistake down the line.
    -J
  4. May 11, 2020 at 11:08 AM
    #44
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    All that other stuff may be great, but I don't need all that stuff, I don't have a lap-top & wouldn't know how to use it if I did, & all I want is for my speedometer in my dash to be relatively corrected for my tire size. A 2.5" taller tire will, according to the tire size calculator, make your speedometer 5 mph. low at 65mph., When showing 65 mph. you'll be going 70 mph.
  5. May 11, 2020 at 11:17 AM
    #45
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Yeah, you'd need a much longer USB cable to reach your desktop. :anonymous:
    That, or keep pulling the dash apart.
    -J
  6. May 11, 2020 at 11:27 AM
    #46
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Wouldn't know what buttons to push on the desk-top either. Not as simple for some as it is others.
  7. May 11, 2020 at 11:38 AM
    #47
    mikkydee
    mikkydee [OP] My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    anybody know where a chart is to determine your tire height by the size? I am riding some LT275/65R20's
    I don't even know what the stock tire size was on it
  8. May 11, 2020 at 11:42 AM
    #48
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Look at your specific tire manufacturer website. Every tire is a little different.
  9. May 11, 2020 at 11:50 AM
    #49
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    On this site home page, click on tire size calculator. Like said there will be small differences from one tire to another, but probably as close as you can expect. looks like yours are 35.65" tall & 112" circumference.
  10. May 11, 2020 at 1:13 PM
    #50
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    True, but how much does that really matter?
  11. May 11, 2020 at 1:24 PM
    #51
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    If it's only 5 mph off how are they going to get blasted doing 20over?
  12. May 11, 2020 at 7:43 PM
    #52
    DG92071
    DG92071 Well-Known Member
    When my trucks speedo says it's going 58 it's actually going 65 mph. 62 mph= 70 mph. Eventually I'll do something about it but it isn't high on the list.
  13. May 12, 2020 at 4:27 AM
    #53
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    So 20 mph was a stretch, but your speedometer to your actual speed will be nearly parallel to each other. So for example, if you're doing 10 mph actual, your speedo will display 9.5. As you increase speed say, to 75 mph actual, your speedo will be off by a much larger number. It shouldn't be a constant 'off by 5 mph through all speeds'. Easy way to check would be do drive 5 mph, does your speedo show you as going 0 mph? I'm sure there's a formula, I'll look it up in a bit. If your speedo is 'off by 5 mph through all speeds', it's more than likely something mechanical/electrical would be my guess.
    -J
  14. May 12, 2020 at 9:45 AM
    #54
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    My speedometer seems to be exactly 5 mph off from speeds at 45 mph and higher. Pretty much exactly 5 mph. 50=55,60=65,70=75,etc. The way I know this is those construction radar signs. You know what ones right? Posted speed and the sign flashes"your speed"? Not very scientific, but I gotta believe they must be close.
  15. May 12, 2020 at 9:55 AM
    #55
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Yeah, the math seems to be fairly close to what you stated.
    I dont remember if you said exactly what your new tire size was, but the numbers dont lie.
    -J
    Grey 2015[QUOTED] likes this.
  16. May 12, 2020 at 10:27 AM
    #56
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    35x12.50x18
  17. May 12, 2020 at 10:40 AM
    #57
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Yours.
    -J
  18. May 14, 2020 at 8:43 PM
    #58
    Taco-Obsessed
    So, with larger tires, 35s (ok, ok 34.5s), my odometer is going to skewed low right?
    I am not as concerned with the speedometer, as I am with the odometer driving all my self servicing (fluid changes, tire rotations, etc).
    I'm curious how off it would be say for 5,000 miles.
  19. May 14, 2020 at 11:52 PM
    #59
    WillyTtaco
    WillyTtaco Well-Known Member
    Bill
    So Cal
    2014 DCSB TRD OFFROAD 4X4
    265/75/16 AT2 BILSTEIN,SNUGTOP MBRP,SPC UCA
    Get a gps mph gauge and stick it on your dash.
    Also the ratio can’t be too far off..I have 285/75/16 and just drove 15+ hours passing tons of sting operations..”80” the whole way people passing me constantly and I know I wasn’t going 85-90 mph.
  20. May 15, 2020 at 4:10 AM
    #60
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I cant remember exactly, but I believe your odometer is pulled from your transmission rotations. The tech site was taken down so I cant confirm but there is a sensor or two on the transmission that tracks rotations/rpm(?) which ties into your gauge cluster via the computer. I ran a dash GPS for about 1500 miles when I first installed larger tires which had a built in trip meter. While my speedometer was wrong, after 1500 miles, my onboard odometer was only off by about 25 miles which I attest to the inaccuracies of the GPS.
    -J
    Taco-Obsessed[QUOTED] likes this.
