Speedometer off by 20mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lurod, Dec 23, 2020.
  1. Apr 6, 2021 at 6:33 PM
    #41
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    When I first got the inline hypertech I changed both tire and gear size due to just installing 4.88’s. With that change the speedo was waay off. Dropped it back to stock 3.90 and only kept tire size changed, then it read proper speed. No idea why the hyper tech has parameters to correct for aftermarket gears when it clearly does not coincide with the changes that otherwise would seem appropriate.
  2. Apr 7, 2021 at 9:13 AM
    #42
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Mostly due to the fact that the Tacoma gets it's ground speed input from the wheel speed sensors, so it wouldn't even matter if you had gears at all (as if you were flat towing it rolling on hubs like a trailer).
    Older vehicles had the ground speed input coming off the transmission or transfer case output shaft speed. Change your gears, you changed your ground speed. Change your tires, you change your ground speed. Change them both the right way and you can get your ground speed input pretty close to accurate again.
    So, with wheel speed input as your only input, that is what our speedos are looking at on these trucks.
    Phich[QUOTED] likes this.
