Speedometer off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KK87, Jun 4, 2016.
  1. Aug 11, 2016 at 7:23 AM
    KP Texan
    KP Texan Member
    Dallas, TX
    How did you go about calculating revolutions per mile? A simple calculation of (63360)/((Tire Diameter)(Pi)) is not the correct way to do this. Read some of the manufacturer numbers and you'll see it is different due to side wall flex and loading.
  2. Aug 11, 2016 at 8:30 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Not enough to make a 5 mph difference....
    Actual diameters of both tire installed for the dyno run and the OEM are 1/2 inch difference when measured both in the air (unloaded) and mounted abd on the ground with the same tire pressure cold.
    You guys are arguing just for the sake of arguing.
  3. Aug 11, 2016 at 8:36 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I gave you the actual measurements of the OEM tires delivered with my truck and the aftermarket tires tested to compare so we have actual values, 1/2 inch difference.
  4. Aug 11, 2016 at 8:59 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    does this account for deviation based on the weight of the truck?
  5. Aug 11, 2016 at 9:02 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    In the air and on the ground with the same tire pressure, same difference in measurements, 1/2 inch overall so sidewall flex is the same.
  6. Aug 11, 2016 at 9:21 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My speedometer reads 3-5 mph high with stock size tires. It was very troubling to find I was going too slow.
  7. Aug 14, 2016 at 7:21 PM
    stanrs48
    stanrs48 Member
    Go by the digital,and same with temp, one on speedometer is outside, the one on display is weathet channel generic
  8. Aug 14, 2016 at 8:46 PM
    justguth
    justguth We beefin??
    2016 White TRD OR DC 4x4
    I heard if you change your blinker fluid and then reset the flux capasitor bearing, the speedo will be dead on. :thumbsup:
    Just stay with the flow of traffic. You'll be fine.
    Synergy001 likes this.
  9. Dec 12, 2016 at 7:15 AM
    Taco280AI
    Taco280AI Well-Known Member
    COS
    2017 TRD OR DCSB 4x4
    I had the opposite of the OP. My digital reads slower than my analog by about 2mph
