Speedometer reads too high
Discussion in '1st Gen. Tacomas (1995-2004)' started by zehrh, Oct 27, 2013.
  1. Nov 3, 2013 at 4:06 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    check the gear ratio will be pretty easy if you just jack the truck up so the rear axle is suspended. Then mark with chalk on the drive shaft and a tire. Have some one spin the tire and you can count the ammount of times it takes the drive shaft to rotate per one rotation of the tire...won't be perfect..but it'll give us a better idea..
    that said..my 96 came with 31x10.5r15s..think it was an option for the SR5 though..can't remember..but my RPMs for 65 where about 2500ish and i have 4.10 diffs.
  2. Nov 3, 2013 at 4:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    B02A is the diff code...
    That's a 3.58 with a 7.5" ring.
    With a 3.55, you'd be running 2500 at 65, so if you're hitting 2330 at 55, that would put you at about 2750 at 65, which would be about right for a rear end in the 3.91 ballpark.
    2750 to 2500 is only about a 10% difference.... the tire change subtracted about 10%, so there's no error there.
    Back to square-1.
    Manually check the ratio as BD describes. If the number seems to be way off, either double or halve your count. Since we know you're somewhere in the 3-5 range, if you only count 2.x, spin the tire once more, if you're at 7, then divide by 2.
    If you only jack up one tire, you need to run two revolutions, and that's a better way to go since jacking up both you would need to have two people to spin both tires.
    It was an optional size.
    For reference:
  3. Nov 3, 2013 at 8:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You guy are over thinking this. The B02A ratio of 3.58:1 would really sap performance of a the 2.7L with 31's. A regear is a reasonable solution especially if the truck has enough power now to push the big wheels.
    Toyota put 4.56s into trucks that came stock with 31s and the 4 banger.
    As for % errors, on 1st gens, a 5% under reported error was typical, where 65 indicated on the speedo would be closerr 62 on the GPS. We have seen this over and over again on trucks that came stock with 31s and 4.10s.
    If the truck originally had 3.58s and now has 4.56s, this could easily explain the speedo error now being seen.
  4. Nov 15, 2013 at 7:31 PM
    zehrh
    zehrh [OP] Member
    Howard
    Broadway, VA
    1996 Tacoma 4x
    oversized tires
    According to the Electrical Wiring Manual, on the 4 cyl. engine, the speed from the speed sensor in the speedometer is one of the inputs fed into the control until to set ignition timing. So now I'm wondering if this is negatively affecting engine performance.
  5. Nov 15, 2013 at 7:48 PM
    zehrh
    zehrh [OP] Member
    Howard
    Broadway, VA
    1996 Tacoma 4x
    oversized tires
    As to the gear ratio, I was away for awhile and am just now getting back to this. I'll try to find out using the method you've suggested. Thanks
  6. Nov 16, 2013 at 6:49 AM
    zehrh
    zehrh [OP] Member
    Howard
    Broadway, VA
    1996 Tacoma 4x
    oversized tires
    Jacking up one tire, 7 turns of the drive shaft give about 3 1/8 turns of the tire. 1 turn of the tire gives about 2 1/4 turns of the drive shaft
    That's a ratio of about 2.25. What does that tell us?
  7. Nov 16, 2013 at 6:58 AM
    zehrh
    zehrh [OP] Member
    Howard
    Broadway, VA
    1996 Tacoma 4x
    oversized tires
    If I'm understanding you right, taking the 2.22-2.25 ratio gives a gearing in the 4.56 range. Digiratus, you said this would explain the speedometer error, right?
    On the ignition timing issue, I'm going to take a reading with my scanner at highway speeds and see what that tells me.
  8. Nov 16, 2013 at 7:52 AM
    cameron172
    cameron172 Well-Known Member
    VA
    2017 Super White TRD Sport MT
    The speedo in my '09 does the same thing, but the difference isn't constant. When speedo reads 20, actual speed (read from OBS scanner, GPS and radar scanners on the side of the road) is 15-17. 30mph is accurate. 75mph indicated is 65 mph actual.
    I'll try to use the light grease on the back of the speedo and see how that works.
  9. Nov 16, 2013 at 10:37 AM
    zehrh
    zehrh [OP] Member
    Howard
    Broadway, VA
    1996 Tacoma 4x
    oversized tires
    On the speedometer repair, take a look up this thread a bit. The lubricant has to be very light!
  10. Nov 16, 2013 at 10:40 AM
    zehrh
    zehrh [OP] Member
    Howard
    Broadway, VA
    1996 Tacoma 4x
    oversized tires
    Up the threat a bit, I concluded that my ratio was in the 4.56 range. Was my calculation right?
    Since the speed sensor in the speedometer console is one of the feeds into the control module for the ignition timing, I'm wondering whether my speed error is affecting performance. I have a scanner that connects to my iPhone, and at 55mph (GPS reading) my RPMs are about 2300 and the timing advance is about 25. Does this seem reasonable?
  11. Nov 16, 2013 at 2:20 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Don't trust the roadside radar units. They are not calibrated regularly.
    We have some out on I-15 near Barstow that, at least a couple of years ago, were reading 10mph high.
