Speedometer Recalibration???
Discussion in 'Wheels & Tires' started by Matt in Knoxville, Mar 30, 2011.
  1. Mar 30, 2011 at 8:12 AM
    Matt in Knoxville
    Matt in Knoxville [OP] Well-Known Member
    Knoxville
    2010 SR5 Access Cab
    Tint, Fat Bob's 3" Lift Kit, 30" Tires, 16" Blacked out Rims, 4 extra D-rings, K&N Drop in Air Filter, Tonneau Cover, Besttop Soft Top, Aries Nerf Bars...more to come...
    I have called all 3 Toyota Dealers in Knoxville and all of them say they cannot do this...I added 3" lift and put larger tires on and my speedometer is off, does anyone know who I can call to fix this issue? I also tried Firestone but they dont do this either...1 toyota dealer says it cannot be done at all, but this cant be true? thanks.
  2. Mar 30, 2011 at 8:15 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    Hypertech makes a box for it or you can use a Dakota Digital box. They hypertech is plug and play where the Dakota Digital requires figuring it out on your own.
  3. Mar 30, 2011 at 8:16 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I have a 3 in lift running 285s and my speedo is the same...and I just regeared yesterday so it should still be the same
  4. Mar 30, 2011 at 8:32 AM
    Matt in Knoxville
    Knoxville
    2010 SR5 Access Cab
    how do you regear, my speedo is off a little bit but i dont want my odometer to be off?
  5. Mar 30, 2011 at 9:29 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Its all fly-by-wire these days, no more gears and cables. There is a sensor that sends the data to the ECU which displays the data on your odometer/speedometer.
    Devices like a ScanGauge can be calibrated for tire size adjustments so you get an accurate speed reading and for calculating fuel mileage but not much you can do with the odometer accuracy.
    At least with bigger tires the odo being off is in your favor. Bigger tires make it read low.
  6. Mar 30, 2011 at 9:31 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    do you know how much your speedo is off? Use a GPS to verify. You might be surprised, larger tires may have actually corrected a speedometer that was running too fast.
  7. Mar 30, 2011 at 9:39 AM
    beans20
    beans20 Well-Known Member
    Will
    Pontotoc, MS
    A Bad MotherF***er!!!
    Soon to come 6" procomp lift Stage I 18x9.5 Black Rhino Sidewinders Kenwood DNX6960 Head Unit and 35x12.50 Toyo Open Country MT's JDM black head and tail lights and more!!!!
    Is the HyperTech accurate does anyone know!!!
  8. Mar 30, 2011 at 9:51 AM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    I've got a 3 inch lift and 285's and according to GPS my speedo is about 3 MPH lower than actual speed.
  9. Mar 30, 2011 at 10:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No....not necessarily. The speedometer on the dash is not accurate.
    That doesn't mean, the ECM isn't accurate.
    I have a Scanguage which displays actual speed from the ECM directly. It matches the GPS. My speedo (on the dash) is 2mph fast. The ECM is accurate but the speedo on the dash isn't calibrated properly.
    Jeeps (atleast the older ones) can swap out their speedo gears - but Toyotas, you can't.
  10. Mar 30, 2011 at 1:21 PM
    Matt in Knoxville
    Knoxville
    2010 SR5 Access Cab
    but how easy is it to install and scanguage...not the mounting part, that is easy....what exactly does it hook up to and where is that located? thanks.
  11. Mar 30, 2011 at 1:56 PM
    Janster
    Jandy
    Lancaster, PA
    Scangauge II
    http://www.scangauge.com/products/
    It's simple - hooks up to your OBD port. OBD port is located under the dash near the steering wheel. This is where I have my scangauge mounted...
    Do some research on the forum. There's a lot of different places people have these mounted. There's another product that's similar - called Ultragauge. I'm not familiar with that but again....search the forum, the info is out there.
  12. May 4, 2011 at 9:59 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    hey man. i think there is a place in maryville or south knox (don't quote me on ether) did you call fox in clinton? jw and i think i heard of a place out west or something. idk.. any ways. if you don't mind me asking what aria of knox you in? im up by Norris like 0.5 miles. i hope to be getting tacoma in the next few weeks. we looked at one at toyota of knox it was '07 trd off road with like 24'800 miles we are thinking about going back and getting it... idk. i kinda hope.
