Speedometer Recalibration?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Em3rtr, Jan 2, 2025.
  1. Jan 2, 2025 at 10:27 AM
    Em3rtr
    Em3rtr [OP] Member
    Emily
    2020 Tacoma SR5 4x4
    2” leveling kit
    I just recently put a little bit bigger tires on my truck. Went from 265/75/r16 to 285s. My speedometer is off by about 3mph. Looking for some direction on how to get this fixed. TIA!
  2. Jan 2, 2025 at 10:31 AM
    545 Well-Known Member
    2015 Access Cab
    Em3rtr[OP] likes this.
  3. Jan 2, 2025 at 10:50 AM
    Em3rtr
    Em3rtr [OP] Member
    Emily
    2020 Tacoma SR5 4x4
    2” leveling kit
  4. Jan 2, 2025 at 10:52 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I also recently went from 265/75/16’s to 285/75/16’s. I have the Hypertech speedometer calibrator and it works well. I have read that it’s the same exact thing as the RC unit, just branded differently.
    musicisevil likes this.
  5. Jan 2, 2025 at 10:53 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    I am running stock tires and my speedometer is off by 2 mph, as measured by GPS on the recent 700 mile trip. I am living with it. Every car I've owned had speedometer off by 2, 3 mph.
  6. Jan 3, 2025 at 4:09 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Hypertech here too. I caught it on sale on the 'Zon. You may have to play with the settings though. I run 35's but have it set so it thinks its on 33's to get the speedo correct. Verified with 2 different GPS's as well. I'm within 1 mph.
  7. Jan 3, 2025 at 3:51 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    get WAZE and forget about it
  8. Jan 3, 2025 at 4:28 PM
    ERod27
    ERod27 Well-Known Member
    Eddie
    2019 TRD OR DCSB
    King 2.5s with Camburg Kinetik UCA Cooper Discoverer AT3 XLT 285/70/R17 17" 4 Runner TRD PRO SEMA wheels TRD PRO skid plate 5.29 Yukon gears Apogee front bumper with Warn EVO Apogee rear bumper with tire carrier
    I installed the RC one. It works great, but you have to mess with the settings until you get close to an accurate reading.
  9. Apr 3, 2025 at 12:40 PM
    TacoDell60
    TacoDell60 Well-Known Member
    does it mess up or play weird with the OTT tune? Or is it a completely separate thing altogether?
  10. Apr 3, 2025 at 1:07 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    It’s a totally different thing. An ECU tune basically reprograms the shift points in the transmission. The speedometer calibrator tells the speedometer that your tires are a different size, essentially.
    I have an old version of the KDMax tune and it all works just fine together.
  11. Apr 3, 2025 at 1:12 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Completely separate. It’s a hardware module that is installed behind your instrument cluster. Takes input from stock sensors on your truck, applies the changes you made when you programmed the module with your computer and sends the adjusted speed to your speedometer.
    TacoDell60[QUOTED] likes this.
  12. Apr 3, 2025 at 3:02 PM
    TacoDell60
    rad, thanks for that info
    musicisevil[QUOTED] likes this.
