Speedometer stopped working correctly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjg, Jul 12, 2011.
  1. Jul 12, 2011 at 6:12 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    2007 Regular Cab 4x4 5 Spd 2.7
    LCE header, AFE filter, Blinglight Fogs, URD Short Shifter, Delay wipers
    This evening on my 2007 4x4 2.7, I noticed my speedometer was way slow. While going 60, the speedometer shows 40 ( verified with another vehicle and GPS). It was fine yesterday..
    I did notice the speedometer needle is now sitting way below zero. It is a certified vehicle still covered by the bumper to bumper. I plan on taking it in but was curious if anyone else has had this problem.:confused:
    Also no mods, stock 245/75-16 tires and factory gearing.
  2. Jul 12, 2011 at 6:19 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    id try disconnecting the battery for a 10 min, reconnect, and test results
  3. Jul 12, 2011 at 6:51 PM
    rjg
    rjg [OP] Yes
    RJ
    PA
    Thanks, I tried that with no avail.. Must be a faulty part. I'll let the dealer check it out.
  4. Oct 7, 2012 at 6:06 AM
    JT Class
    JT Class Can't spell class without...
    JT
    Sept-Iles, Canada
    09 DC TRD Sport
    Aries bull bar, Tonneau pro box cover, TrailFX hood deflector, Sleeper lids, US Speedo speedometer gauge (white), more to come...(3incher bilsteins 5100+f/coils+aal w/285 or 265?)
    Any news on what it was??
  5. Oct 7, 2012 at 7:03 AM
    rjg
    rjg [OP] Yes
    RJ
    PA
    The dealer replaced the speedo cluster under warranty. They tried several things that didn't work(I can't recall what). Then they swapped a speedometer cluster from another truck. That worked. I have no idea what was wrong with the other cluster. They said it was the first one they saw with a problem....
  6. Oct 7, 2012 at 7:12 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Maybe stripped plastic gears in the needle assembly?
    Frank
