Speedometer stopped working even after replacing speedometer cable
Discussion in '1st Gen. Tacomas (1995-2004)' started by up on1, Apr 15, 2013.
  1. Apr 15, 2013 at 7:37 PM
    up on1
    up on1 [OP] Bort to be alive
    Gene
    York, SC
    T100 DX
    Truck information:
    1995 Toyota T100
    3.4L V6 2WD 5 speed manual transmission
    The speedometer stopped working at 316,906 miles but before it broke it the speedometer needle was bouncing a little. I thought for sure it must be my speedometer cable so I bought one but I was wrong. I hooked a cordless drill to the old speedometer cable where it screws into the transmission and the drill was able to make the speedometer read 10 miles per hour even after having a weak charge. I was going to return the new speedometer cable but while I was there I changed it anyway. Now I need to find what else is causing my speedometer to not work. Any ideas would be helpful.
    Thanks,
  2. Apr 15, 2013 at 7:43 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    sounds like a gear in speedometer itself is bad. get a new speedo from the junkyard.
  3. Apr 15, 2013 at 7:44 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    replace the speed sensor in the transmission
  4. Apr 15, 2013 at 9:14 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I concur.
  5. Apr 16, 2013 at 6:19 PM
    JudoJohn
    St. Louis
    if he has a cable, it is not electronic. I think it does not have a speed sensor.
  6. Apr 16, 2013 at 7:08 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I think he (and I) meant speedo gear thats inside the transfercase behind the rear output flange.
  7. Apr 16, 2013 at 8:27 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    this except he has a 2wd and therefore doesn't have a transfer case
  8. Apr 17, 2013 at 4:32 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Fine. Tail housing of the transmission. That's what I get for not using my reading comprehension skills.
  9. May 25, 2013 at 2:59 PM
    up on1
    Gene
    York, SC
    T100 DX
    Turns out my ADAPTER ASSY, SPEEDOMETER CABLE is broken.
    Part: 38770-34010
  10. May 25, 2013 at 3:03 PM
    up on1
    Gene
    York, SC
    T100 DX
    Here is what part looks like off my truck.
