Speedometer troubles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stellar, Aug 26, 2022.
  1. Aug 26, 2022 at 9:22 AM
    Stellar
    Stellar [OP] Member
    Scott
    2006 Navy Blue Tacoma 4x4
    None as of yet
    Hey fellas, first post here…
    My speedometer on my 2006 Access cab 6speed stopped working, then came back and this happened a few times. Now this morning it was bouncing around and ended up reading double the speed and adding double the mileage!! So when I’m going 90kmh (Canada) it registers 180kmh and since it’s governed to not go more than 180 I can only go 90 and it bogs back down. Should I just replace the cable? I haven’t been under it to have a look yet but I figured I’d ask here first. Thanks!!
  2. Aug 26, 2022 at 10:21 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no cable. That is Old school like me. It does use a sensor that is driven by a gear for the manual transmission.
    The 4X4 is on the transfer case and the 4X2 is on the tail shaft.
    TnShooter, SR-71A and Dm93 like this.
  3. Aug 26, 2022 at 10:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd inspect the wiring and connector for corrosion, rubbed spots, or broken wires.
    TnShooter and Jimmyh like this.
  4. Aug 26, 2022 at 11:35 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good idea, start with the wiring.
    Always start with simple!
    Dm93 likes this.
  5. Aug 26, 2022 at 6:31 PM
    Stellar
    Stellar [OP] Member
    Scott
    None as of yet
    Ah ok. I’ll crawl under tomorrow for a gander. Thanks for the info. Appreciate it!
