speedometer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SMARTGUY, Feb 25, 2015.
  1. Feb 25, 2015 at 5:16 PM
    SMARTGUY
    SMARTGUY [OP] New Member
    Third Lake Ill.
    2006 Toyota Tacoma
    Does any one know….can the speedometer be re calibrated or corrected after new tires and wheels installed that are one size up from the original tires/wheel??…Thanks..Steve in Third Lake Ill.
  2. Feb 25, 2015 at 6:23 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
  3. Feb 25, 2015 at 6:27 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    One size up from stock (example: going from 265/70/16 to 265/75/16) makes your speedometer read correctly. It reads ~3% slow from the factory. However, your odometer will now show a ~3% deficit and this must be accounted for in you mpg calculations. Bonus is that when and if you do sell the vehicle, the odo will show less than actual mileage
    That said, if you really want to spend $, look at hyper tech
  4. Feb 26, 2015 at 4:03 AM
    k9cinco
    k9cinco Active Member
    New Jersey
    2012 double cab sb 4x4
    None yet
    I just installed a hypertech plug and play module on my 12...works well so far
