speedway blue stuff???
Discussion in 'Detailing' started by Bearskill, Dec 8, 2008.
  1. Dec 8, 2008 at 1:26 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Ok, has anyone heared anything about the 05+ speedway blue paint chipping easier than other paint colors? I haven't done any off roading yet and I have noticed like ten little chips show up all a sudden. I got the bug/stone deflector, and the are just little wussy chips, but my truck is my baby. Any thoughts?
  2. Dec 8, 2008 at 1:55 PM
    Drewster
    Drewster Well-Known Member
    Portland, Oregon
    09' Pyrite Mica V6 TRD Off-Road
    BugDeflectorII, Tube Steps
    Touch up paint or scratch remover. I am having chip problems as well with my Pyrite Mica paint, it seems to chip and show a lot more too. It's only a couple months old too. :mad: I just ordered a AVS BugDefector I sure hope that will help before i Grind all my teeth off
  3. Dec 8, 2008 at 3:30 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No problems here....only one chip (deep) that I know of on the hood. It does seem easy to scuff/chip. I've hit the sides with stuff and its scuffed pretty easily. I use http://www.langka.com/ to help repair.
  4. Dec 8, 2008 at 5:08 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    The Bugflector 2 fits perfect and protects it bigtime. I knew this to be the case from the past and had mine on within 2 days of driving my truck off of the lot. You can't 'unchip' it after the fact...
    This is also the reason i had the step bumper on within 6 days (protect the rear area from stones ricocheting up after relasing from the front tires) and know its not smart to remove the mudflaps for this reason.
    I had a $#itload of chips on my black sand pearl rear wheel areas jsut from not adjusting my front flaps after putting bigger (and wider) tires on the front. First thing i would see when i would walk by, especially with the grey primer under the black.
    I learned from my past experiences, especially with what they want for these things now.
