Spend my money: need front wheel bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glock24, Aug 28, 2023.
  1. Aug 28, 2023 at 12:25 PM
    glock24
    glock24 [OP] Well-Known Member
    I have a '15 DCSB TRD OR with 157k. I think it's time for new front wheel bearings. I get the grumbling sound which I can only hear at low speed (right now)
    I found the gentleman here on TW selling replacement NSK bearing assemblies ($325) and I'm going that route. The plan is to purchase parts and work with my local mechanic.
    A couple questions though;
    1. Knowing I'm paying for labor, would it be prudent to also replace CV joints at this time? They aren't bad that I know of, but it would be convenient.
    2. Should I be considering anything else while I'm at it?
    Thanks in advance
  2. Aug 28, 2023 at 1:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You need the O-ring between the bearing hub and spindle.
    And the dust seal in the back side of the spindle.
    Some guys swear you need the seal on the CV too.
    It’s a pain to get on and off. And I never change the seal on the CV.
    It only gets changed when I change a CV.
    If your CVs are fine. Leave them alone.
    Don’t change them, OE CVs are about the best there are.
    I did my bearings at 135k. Stuck the OLD CV right back in.
    You’ll also need a new cotter pin for the axle nut.
    But surely the shop will have one that fits.
  3. Aug 28, 2023 at 4:24 PM
    TacoTuesday1
    SD CA
    You can do them yourself.
    reboot CV’s if needed.
    ECGS bushing
  4. Aug 29, 2023 at 9:14 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    I wouldn't worry about replacing the axles. I just replace mine at 303K miles only because the boots were tore.
  5. Aug 29, 2023 at 10:40 AM
    glock24
    Thanks for the feedback, gents!
    Hayden334 and TnShooter like this.
