Spew sound when starting 08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alabamaprerunner, Jul 3, 2012.
  1. Jul 3, 2012 at 4:53 PM
    Alabamaprerunner
    Alabamaprerunner [OP] Member
    Alabama
    08 PreRunner
    K&N
    Started my truck today and made a spewing/blow off valve kinda sound. Had been sitting in 100 degree heat all day. Any idea what this is? Major issue?
  2. Jul 3, 2012 at 4:56 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Coolant spilling into the overflow tank when the water pump started up??
  3. Jul 4, 2012 at 2:15 PM
    Blackbear
    Blackbear Hardtooree Member
    Maine
    2008 Blk SR5 2.7 4X4 5 spd ACab
    (DIY)...Fog lights, alloys, wheelwell liners, tonneau, frame cleanup & rustproofing, floor mats, trailer hitch.
    I get the same thing with my 08' SR5 4X4 2.7, it's been like that since I got it early last year. Doesn't matter whether it's hot or cold outside. Sounds like a little 'pop' from the tail pipe when starting it up after it sits overnight or all day. Have no idea what causes the noise (maybe a little residual gas left in the cylinders), but it doesn't seem to affect how it runs...like a top.
  4. Jul 4, 2012 at 2:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Is your AC turned on?
    If mine is on when I start, or if I hit the button before the engine idles down, I'll get an "odd" noise.
  5. Jul 4, 2012 at 5:52 PM
    Alabamaprerunner
    Alabama
    08 PreRunner
    K&N
    Yes ac was on. Drove it around 100 miles since yesterday. No issues and hasnt happened again.
  6. Jul 4, 2012 at 6:02 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    just set your waste gate higher on your turbo :)
  7. Jul 4, 2012 at 6:33 PM
    mclapperton
    mclapperton Well-Known Member
    Sacramento, CA
    2019 TRD Sport
    The air pump for the emissions system makes some noise at first start up??????
  8. Jul 5, 2012 at 12:02 AM
    The Traveler
    SoCal
    Yes it does, it blows hot exhaust into the cat to heat it up at cold start, but if he hasn't noticed it until now, and especially on a hot day, I kinda ruled that out.
  9. Jul 5, 2012 at 1:08 AM
    Alabamaprerunner
    Alabama
    08 PreRunner
    K&N
    Just bought the truck a month ago. I've know Chevy "noises" all my life. New to the Tacoma world but love it so far.
  10. Jul 5, 2012 at 8:05 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    mine does the same thing. usually when I start backing up. emissions system.
  11. Jul 5, 2012 at 8:43 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I could be mistaken, but I believe the air pumps are only on the 2012+ V6.
    You are likely hearing what Rich described. The refrigerant in your a/c system condensed and when your compressor started up the condensed refrigerant rams into the compressor. This usually only happens on hot days. Best way to avoid this is to leave your a/c off until the first minute or two of engine operation.
  12. Jul 5, 2012 at 2:57 PM
    Alabamaprerunner
    Alabama
    08 PreRunner
    K&N
    Thanks for all the help guys!
  13. Jul 5, 2012 at 6:17 PM
    Blackbear
    Maine
    I'd be surprised if it's the a/c system since I never use my a/c and it still happens most of the time, summer or winter, when starting up after a long sit. Maybe a good question for the dealer.
  14. Jul 5, 2012 at 6:38 PM
    Maticuno
    2011 Suburban 2500
    Your 2.7 does have the air injector blower that would make a noise on startup.
  15. Jul 6, 2012 at 2:20 PM
    Blackbear
    Maine
    Thanks for the tip. That's interesting, I wouldn't have guessed that the blower would be an issue unless the a/c was actually being used. Mine probably has cobwebs on it...not too many hot days here. Short of removing the a/c, is there a fix for the noise?
  16. Jul 6, 2012 at 2:51 PM
    Maticuno
    2011 Suburban 2500
    Two different systems creating two different noises. The noise on startup with the blower is an emissions thing and it blows air into the exhaust manifolds before the catalytic converters to help give a more complete combustion. It will do this regardless of outside air temp (I think).
    The noise from the a/c system is entirely independent of the emissions blower.
  17. Jul 7, 2012 at 5:33 AM
    Blackbear
    Maine
    Learned something new, I appreciate the explanation. Truck runs great so not a worry, but at least the minor mystery on the 'poof' noise seems to have been solved.
