Spicer U-Joint Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imageoguy, Jun 3, 2025.
  1. Jun 3, 2025 at 8:33 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    I'll soon be installing a new set of 3 U-joints (Spicer 5-1330-1X) and carrier bearing (Spicer 5002007) on my taco drive shaft. I received my parts today, and I seem to be missing at least one copper snap ring for a U-Joint. I don't quite get the instructions, they seem to say that usually, the copper colour snap rings are used in the 4 ends of a U-Joint, but I only have 3 of each colour (copper, grey and yellow), plus a different kind of open snap ring. Also, seems like I only have two copper snap rings in the unopened hardware bags. I would appreciate any help on this and which colour snap rings are usually used on our trucks.
  2. Jun 3, 2025 at 8:42 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    They are different thicknesses. Use the one that matches what is removed. It should keep the caps tight.
  3. Jun 5, 2025 at 2:11 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    U-joints contain precision bearings & are best assembled to a tolerance of +/- 2 thousandths of an inch.
    For your best shot at doing the removal of old / installation of new U-joint bearings you may want to invest a couple of hours learning the correct methods which will avoid common forms of damage such as bending the driveshaft yoke ears, installing U-joint bearings with too little (or too much) end play, etc. Here's another post I made w/ links to the videos.
    U Joint Install Issues?
    Pbuddy1026 likes this.
  4. Jun 5, 2025 at 4:42 PM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    The open "C" looking snap ring goes on the spider end with the grease fitting. The ones that look like a "G" go in the spider ends (3 of them) without the grease fitting.
    I used Moog 270 U-joints when I rebuilt my driveshaft 4K miles ago, so I cannot talk to the different thicknesses of the snap rings. The snap rings are all the same thickness with the Moog 270 U-joints.
  5. Jun 5, 2025 at 8:52 PM
    Imageoguy
    2012 DCLB SR5
    Thanks GilbertOz, I did go through that post, good vid with lots of interesting info. Much better than some of the other vids where people are pounding with a sledge hammer on their U-joint!
    Thanks! I didn't see that in any vids, and the instructions don't show that "C" looking snap ring. RockAuto sent me a replacement in record time including the missing ring. Looking to do the work this weekend. I also have a press which could come in handy.
  6. Jun 5, 2025 at 10:00 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
  7. Jun 5, 2025 at 10:13 PM
    GilbertOz
    GilbertOz Driver
    CA
    Aye, you may not have a dial indicator etc. to do a perfect job but at least you have an idea of what to look out for and how to avoid the worst errors.
