Spider owners tips, feed videos and BS
Discussion in 'Pets' started by rtzx9r, Jun 7, 2018.
  1. Mar 27, 2020 at 3:29 PM
    #1481
    Kwikvette
    Fresno County
    4 run, 2 don't
    So I didn't ask; pics of your goliath in the new enclosure?
    Being a Theraphosa, I know they require a good deal of humidity.
    Be curious as to how you've got your enclosure set up, what you're using for substrate, and how warm the room is where your enclosure is kept?
    boogie3478[QUOTED] and Pinay like this.
  2. Mar 27, 2020 at 4:28 PM
    #1482
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    A fish is the most normal pet I've ever had. :D
    CurtB[QUOTED] likes this.
  3. Mar 27, 2020 at 4:36 PM
    #1483
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I'm using this medium enclosure: https://www.amazon.com/dp/B0002AR48O/ref=twister_B005HSG4NC?_encoding=UTF8&psc=1
    A few pics attached below, but the enclosure has slits on the 2 long walls which will be great for cross-ventilation. The bad part is that is has slits on the top as well which will allow moisture to dry faster. As I mentioned earlier I'll attach some pieces of plexiglass to the top of the enclosure to block those top vents. Additionally I've got a good deal of moss around the hide which is a planter that will also absorb water. The moss is great at holding water too. I'll probably mist the enclosure daily or every other day, in addition to soaking the substrate as needed. No water dish right now but I might add that tomorrow too. I keep the office around 70 degrees which should be fine.
    The theraphosa blondi (Goliath Bird-Eater) is probably the most humidity-dependent species of T you can get and definitely require more attention than others.
    Pinay likes this.
  4. Mar 27, 2020 at 4:39 PM
    #1484
    Kwikvette
    Fresno County
    4 run, 2 don't
    Damn that's a lot of moist substrate.
    But yes I'm familiar (from my readings) that they are very dependent on a humid environment.
    Can't wait to see it modified
    boogie3478 likes this.
  5. Mar 27, 2020 at 4:43 PM
    #1485
    boogie3478
    14 TRD Off-Road V6
    All the mods
    One important thing to mention after watching this video. It looks like that guy was using regular silicone which can be hazardous for pets. This is a safer alternative: https://www.amazon.com/Aqueon-10016...85352456&sprefix=pet+safe+sili,aps,147&sr=8-3
    Pinay likes this.
  6. Mar 27, 2020 at 4:44 PM
    #1486
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Lol I'll probably moisten the substrate even more. Just wanted to see how it would soak in.
    Kwikvette[QUOTED] likes this.
  7. Mar 27, 2020 at 4:58 PM
    #1487
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wonder if I'll find anything like that locally
    There was a big aquarium store that closed up shop about a year ago and that place would've been perfect
  8. Mar 27, 2020 at 5:02 PM
    #1488
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Just try Amazon. All of the stuff I've recently ordered has only been delayed a few days.
  9. Mar 27, 2020 at 5:05 PM
    #1489
    Kwikvette
    Fresno County
    4 run, 2 don't
    Eh...my residential/address thing will spin your head.
    Amazon is my last resort.
    Was hoping to knock this out as a project for tomorrow
    boogie3478[QUOTED] likes this.
  10. Mar 27, 2020 at 5:18 PM
    #1490
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Goliath settling in nicely ...
    ... before num num num time
    Pinay, Kwikvette and irayfz6 like this.
  11. Mar 27, 2020 at 5:32 PM
    #1491
    Kwikvette
    Fresno County
    4 run, 2 don't
    @boogie3478
    @Pinay
    My OBT already went through a molt!
    No wonder it didn't want to eat yesterday!
    The molt
    The T in hiding on the other side of the enclosure; hard to see but there's a bit of that blueish hue on the bottom of its legs
    irayfz6, Pinay and boogie3478 like this.
  12. Mar 27, 2020 at 5:34 PM
    #1492
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Sweet! Make sure you wait a few days before trying to feed it again.
    Pinay likes this.
  13. Mar 27, 2020 at 5:42 PM
    #1493
    Kwikvette
    Fresno County
    4 run, 2 don't
    Absolutely
    Those fangs are soft
    irayfz6, Pinay and boogie3478[QUOTED] like this.
  14. Mar 27, 2020 at 5:42 PM
    #1494
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even as a molt its in threat pose :rofl:
    boogie3478 and Pinay like this.
  15. Mar 27, 2020 at 6:22 PM
    #1495
    Kwikvette
    Fresno County
    4 run, 2 don't
    As for my other T, it's barely responsive, so I moved it into ICU :pout:
    Covered it, burned some holes through the plastic enclosure lined with moist paper towels, soaked a small bit of moss and put it in there as well, small water dish, and covered to keep light from entering.
  16. Mar 27, 2020 at 8:07 PM
    #1496
    JimCar28
    JimCar28 Well-Known Member
    Jim
    < 25 miles from the Tarrant Co. Tx Court House
    2020 Quicksand Off-Road 4X4
    Tyger Tonneau Cover RCI Full Skid Package RCI Rock Sliders (no plates)
    Something I do/have done, keep a small hand towel or similar over the top grill. Enough air will get through and you can mist the towel without excess moisture in the enclosure. On cool nights it holds a couple of degrees of temp. Easy to get out of the way if needed.
  17. Mar 27, 2020 at 8:46 PM
    #1497
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I'm considering doing this is well since it would be an easier way to help block the air flow ... but for the tarantula in this specific enclosure excess moisture is a good thing. Adding some plexiglass wouldn't be too involved and would be easier on the eyes compared to the towel method though. :D
  18. Mar 28, 2020 at 9:21 AM
    #1498
    Kwikvette
    Fresno County
    4 run, 2 don't
    Removed the towel I had covering the ICU enclosure....
    A.Versicolor did not make it through the night.
  19. Mar 28, 2020 at 9:47 AM
    #1499
    boogie3478
    14 TRD Off-Road V6
    All the mods
  20. Mar 28, 2020 at 9:48 AM
    #1500
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Is it on it's back or death curl with legs under it?
