Spidertrax 1.25" wheel spacers (hubcentric) with Method Race Wheels 304/305s??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TrojanTaco_92, Feb 1, 2022.
  1. Feb 1, 2022 at 10:40 AM
    TrojanTaco_92
    TrojanTaco_92 [OP] Member
    J
    '21 Cement Taco DCLB
    We all know most aftermarket wheels are lug-centric.
    We all need to run spacers for clearance/wide stance aesthetics.
    The wheel spacers were installed professionally by my local off-road shop.
    Will I be running into any issues running with the Method Wheels NV 305/304s (lug-centric) with the wheel spacers (hub- centric)???
    Shoulder I not use the center caps? Is it okay to run the center caps??
    Anyone out there with similar experiences? asking for a friend :))))))))
  2. Feb 1, 2022 at 11:48 AM
    TrojanTaco_92
    J
  3. Feb 1, 2022 at 11:53 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    If you are buying new wheels why not get ones with the offset that you want?
    TrojanTaco_92[OP] and na8rboy like this.
  4. Feb 1, 2022 at 11:57 AM
    TrojanTaco_92
    J
    Need to run the 1.25" spacer due to Total chaos gussets on the spindles. I really like the look of the Methods 304 NV double standards (machine). its a 0mm offset, Im not worried about clearance at all due to already cutting, and doing a cab mount chop.
    More worried about if its gonna strain the lugs too much and break shit off, during wheeling.
  5. Feb 1, 2022 at 12:16 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    isnt there a spacer to make them hub centric?
  6. Feb 1, 2022 at 12:20 PM
    TrojanTaco_92
    J
    Well the spider-trax spacer for 3rd gen tacomas are hub-centric already, but Method wheels 300 series are lug-centric, i think what you meant was getting a lugcentric spacer.?
    I think people usually just run the set-up, and hope for the best especially when the wheel is professionally centered and installed by a shop, at least based on what people are telling me around local shops. lol
    I know they make hub rings which may help with the fitment, but with the push through center caps may not be a good fit.
  7. Feb 1, 2022 at 12:59 PM
    wake100
    Syracuse, NY
    I was thinking the hub rings. apparently no help from me :playball:
    TrojanTaco_92[OP] likes this.
