Spidertrax and shortshifter...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Feb 14, 2009.
  1. Feb 14, 2009 at 3:18 PM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I'm considering buying these two for my truck and just wondering if any of you had opinions on these?
    What are the ups and downs?
    I'm considering getting the spidertrax wheel spacers and wanted to know what backspacing meant.
    I also want to get the short shifter from URD but wanted to know if there were any disadvantages.
    Thanks ahead of time.
    Which would you guys get first?
  2. Feb 14, 2009 at 3:35 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    For the Spidertrax I have not heard any negative things about it nor have I with the URD Shortshift
  3. Feb 14, 2009 at 3:37 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Spidertrax are pretty good from what I hear :thumbsup:
  4. Feb 14, 2009 at 8:01 PM
    1tacoplease
    Temecula
    Is there any sacrificing the turning radius? What does backspacing mean? I've heard complaints about that with spacers.
  5. Feb 14, 2009 at 8:09 PM
    Lentsnh
    Since your wheels have more "wheel" to them it would make a better radius.
  6. Feb 14, 2009 at 10:16 PM
    1tacoplease
    Temecula
    Which should I get first?
  7. Feb 14, 2009 at 10:40 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Backspacing is the distance from the inside wheel mounting surface to the inside edge of the rim. If you had the wheel off, and could put a straightedge on the back side of the wheel, the distance from that straightedge to the wheel mounting surface would be the backspacing. The smaller the backspacing, the further out the wheel is. How much the backspacing will be changed is the thickness of the spacers you use.
    IMO, the spacers are not going to affect turn radius where you would notice.
  8. Feb 15, 2009 at 6:39 PM
    1tacoplease
    Temecula
    Thank you.
    I can't see any disadvantages to that.
    I just wanted a bit of a beefier look. The only disadvantages I could think of is kicking up rocks when I wheel, which is not much, but I do go.
    An advantage I can see is a wider base, which would slightly prevent rolling??? It's just a thought.
    Would adding wheel spacers mess up alignment, camber, tow?
    What would you get first, shortshifter or wheel spacers?
