spidertrax Loctite
Discussion in 'ToyTec Lifts' started by big hunter, May 28, 2010.
  1. May 28, 2010 at 5:39 AM
    big hunter
    big hunter [OP] Member
    PA
    TRD
    Got a new set of spidertrax spacers and do i need to put loctite on the lugnuts any info welcome
  2. May 28, 2010 at 8:30 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Don't know if this is the right subforum for your question, but I'd be interested as well since my spidertrax spacers are in the mail to me :)
  3. May 28, 2010 at 8:43 AM
    USMC Mex
    USMC Mex Active Member
    Sun City, CA
    10 PreRunner TRD
    Just gettin started!
    I have read that some recommend the use of blue loctite on there spidertrax spacers when installing.
    I personally purchased a set of All-Pro spacers and when I picked them up i asked this same question. They did not recommend the use of loctite with there spacers. They did however recommend re-torquing them after 10 miles and to recheck them every 10 miles until re-torquing was not needed. I found that on my particular application there wasn't a need to re-torque as they hadn't loosened at all.
    I still check them when rotating tires and still havn't found the need to re-torque.
  4. May 28, 2010 at 8:44 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    locktite on the original lugs, they will be the lugs holding the spacer to the hub.
  5. May 28, 2010 at 8:45 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    X2. Def use some loc-tite on those lugs.
  6. May 28, 2010 at 10:34 AM
    SCFirefighter
    Stephan
    Cary, NC
    Let's add a dumb question: How do you break the loctite? I thought that stuff was forever (as in, f'ing hard to undo).
    Also, I guess I'll have to get a torque wrench when my spacers come in Tuesday.
  7. May 28, 2010 at 11:30 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    18" breaker bar does the trick. Locktite holds the nut in place but will not permanently weld it to the stud.
  8. May 28, 2010 at 11:38 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Blue Loctite is serviceable.
  9. May 29, 2010 at 10:16 PM
    big hunter
    PA
    TRD
    thanks guys
