Spidertrax problem
Discussion in 'Wheels & Tires' started by kram, Jun 7, 2010.
  1. Jun 7, 2010 at 4:01 PM
    kram
    kram [OP] Well-Known Member
    Squamish, British Columbia
    09 TRD Offroad Access Cab 6spd MGM
    URD Short Shifter TSB Leaf Pack, Bilstein 5100s front (1.75") and rear. 285/70/17 Duratrac on Rhino Sidewinders. Weathertech Digifit Floormats
    I have just installed spidertrax wheel spacer front and rear.
    At about 85km/h I started getting vibration at the wheel that got worse as I went faster.
    So I pulled the front right spacer off and put the wheel back on to try and determine if it was a left or right problem. Test drive was good with no vibration with front right as stock and all others with spacers.
    Then I cleaned up both surfaces and reinstalled taking extra care to gradually tighten the bolts all around to make sure it seated correctly. Test drive resulted in vibration, but possibly a little better than before.
    So then I pulled the spacer off and swapped it out with one of rear spacers and reinstalled it on the front right. It still vibrates, but not until about 90km/h and not as bad but still enough to bother me.
    Has anyone else had this problem? Any ideas on what to try next?
    Please keep arguments against wheel spacers out of this discussion.
  2. Jun 7, 2010 at 4:05 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    did u get the hub centric model?
  3. Jun 7, 2010 at 5:03 PM
    kram
    Yes
  4. Jun 7, 2010 at 5:11 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You've just moved your wheels out 1.25" without a realignment. Why wouldn't it vibrate?
  5. Jun 8, 2010 at 7:39 AM
    kram
    Can anyone else comment on this? I had heard that an alignment was not necessary from others that have installed these. The above sounds reasonable, but I don't want to get an alignment if it's not the problem. Funny thing is that it didn't have any vibration or alignment problems when I was ripping down the highway at 100km/h with only 1 spacer on the left and nothing on the right which I thought for sure would fark the alignment.
    I'm sure there's a lot of people here with these spacers, particularly since we just had a group buy. Can some people please comment if they have had any problems or not. Or whether they needed an alignment and if that fixed vibration.
    Thanks in advance.
  6. Jun 8, 2010 at 7:58 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Do you have the original TRD alloy wheels, or aftermarket?
  7. Jun 8, 2010 at 8:01 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Sorry, you Sir are incorrect. One would not need a wheel alignment after the installation of wheel spacers. They have nothing to do with caster/camber.
  8. Jun 8, 2010 at 8:25 AM
    kram
    Original TRD Offroad Alloys
  9. Jun 8, 2010 at 8:27 AM
    drew02a
    San Antonio, TX
    It's possible your tires wore unevenly with only one spacer on. And now that they've both got spacers, they're vibrating.
    How much pressure do you have in your tires?
  10. Jun 8, 2010 at 8:36 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    retighten and recheck your work
    then check out your tires for uneven wear
  11. Jun 8, 2010 at 9:28 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Make sure you Torque both the wheel spacer and the wheel properly. The other thing would be that that wheel/tire is not quite balanced. Rotate your wheel/tire front to back and see if it goes away.
  12. Jun 8, 2010 at 10:10 AM
    kram
    Thanks for all the replies.
    I seem to have reduced the problem to an acceptable level.
    I moved a spacer from the back to the front and reinstalled and retourqued both fronts with a torque wrench after lightly sanding the wheel and hub contact surfaces. I've had those damn things on and off a few times now with the factory jack and a hand wrench and what a pain in the ass that was. I'm glad that it's finally pretty much sorted. Very slight vibration now, but I'm not sure if I'm just being picky at this point due to focusing on it so I'm going to call it fixed and just enjoy driving it again.
  13. Jun 8, 2010 at 2:35 PM
    Racer78
    Racer78 Well-Known Member
    05 Tacoma 4X4 Sport
    Billstiens 5100 @1.75, 5125, 1.5 AAL,Leaf Spring TSB,TRD Intake, Roof Rack, Satoshi Grill, BHLM,T-Rex Eyelids, Undercover Cover, Powdercoated Sport Rims, KC Slimline 8" Lights, MTX ReQ5 w/ipod imput, 12" Shallow Pioneer Sub, RF 800.4 amp, JBL Comp, Bed Ext, USB Port, Shorty Antena, Spider Trax Spacers,TRD Skid Plate, Napier Sportz Tent II, Scangauge II, AirBedz
    Mine have no issues. Other than the usual stuff when installing, I also cleaned the surface of the drum/hubs and put some anti seize on the contact surface of the spacers. Might help seat them?maybe not.. but mine are solid.
