Spidertrax spacer & fj trail teams
Discussion in 'Wheels & Tires' started by Aerial Tacoma, Feb 19, 2013.
  1. Feb 19, 2013 at 8:01 PM
    Aerial Tacoma
    Aerial Tacoma [OP] Well-Known Member
    Andre
    Kodiak Ak
    2010 TRD Off Road Access Cab
    TRD Cold Air Intake, TRD Catback, Original HomerTaco Raptor Grill, TRD Trail Teams "Black", Duratrac 265/75/16, ALL PRO apex rear bumper, Retrofits W/ BHLM halos and deamon eyes
    So trying to prep for the future on lift kits and on most of the stuff I want require a 4.50 Max wheel backspacing. Since I have FJ trail teams wheels which has a backspacing just under 5in I am going to need spacers so I am looking a spidertrax 1.25 since it seems like they get great reviews from you all..
    Question is will the hub centric spidertrax work with trail teams wheels? been searching for a while if the fj's wheels are hub or lug centric with no joy..
    If anyone has this wheel/spacer combo that would be awesome..
  2. Feb 19, 2013 at 10:03 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Spidertrax, All-Pro, and Bora all make hub-centric adapters that will work with the FJ wheels. You will not have a problem with any of them.
  3. Feb 19, 2013 at 10:11 PM
    Aerial Tacoma
    Andre
    Kodiak Ak
    Cool thnx
  4. Feb 20, 2013 at 5:38 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Plenty of folks run the trail teams wheels with 285's without the need for spacers.
  5. Feb 20, 2013 at 12:43 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    I'm going to take a wild guess that he's looking at 6" drop bracket lift kits. Most of those kits require 4.5" or less for clearance.
  6. Feb 20, 2013 at 1:47 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Don't they usually require 17" wheels too?
    Or are the spacers necessary so you can get away with using 16" wheels.
  7. Feb 20, 2013 at 5:24 PM
    Aerial Tacoma
    Andre
    Kodiak Ak
    Correct.. But not going for a 6". the spindles I want from camburg says they have a max of 4.5". Eventually going for a mid travel setup.. Plus would not mind the wider stance
