Spidertrax Spacers
Discussion in 'Wheels & Tires' started by hanaleitaco, Oct 25, 2010.
  1. Oct 25, 2010 at 5:41 PM
    hanaleitaco
    hanaleitaco [OP] Active Member
    Randall
    Kauai
    08 4x4 SR5 V6
    Will the spidertrax spacers fit on a stock 2008 tacoma. No Lift
  2. Oct 25, 2010 at 11:08 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    They will.
  3. Oct 25, 2010 at 11:09 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what are you looking to get from adding them?
  4. Oct 25, 2010 at 11:09 PM
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    make sure you get the hub centric spacer the other ones they make are for earlier gens
  5. Oct 26, 2010 at 4:10 AM
    H0LLYW00D
    H0LLYW00D Well-Known Member
    Spacer question for the truck gurus, i want to run Mickey Thompson 17X9 0mm offset with 5" backspacing on my 2009 4x4 double cab with a 3" Icon lift and Total Chaos UCA and was told by Total Chaos that for these rims to work i need about a 1/4" spacer, would the Spidertraxx 1.25" be too much? or would they work? I want to run a Mickey Thompson Baja MTZ Radial in 285/70/17.
  6. Oct 26, 2010 at 5:30 PM
    hanaleitaco
    Randall
    Kauai
    08 4x4 SR5 V6
    Put the 1.25" spacers on yesterday and they ride and look better than stock. Wider stance makes the truck look a lot better. No rubbing issues. Will post some pics later. Thanks for the help.
