SpiderTrax
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IslandBoy71, Aug 27, 2010.
  1. Aug 27, 2010 at 10:48 PM
    IslandBoy71
    IslandBoy71 [OP] Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    I'm gonna install a set of Spidertrax on my front end to clear my tires. How much torque should I use on the mounting bolts?
    thanks!
  2. Aug 27, 2010 at 10:50 PM
    chozomo
    chozomo Active Member
    Adam
    Vermillion, Alberta
    10 DC TRD White, 92 SR5 pickup
    Extra fuel tank, fire ext, light force driving lights , TRD exhaust, ARB and Warn winch, Bushwhacker, toytec ultimate lift, dakar leaf springs, 18' ATX thugs
    i imagine 85 FT-LBS
  3. Aug 27, 2010 at 10:52 PM
    IslandBoy71
    Reggie
    Lakewood, CA
    would I use the same amount of torque on the wheel lugs?
  4. Aug 27, 2010 at 10:52 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    x2 I believe 84 ft/lbs is what i used for mine
    yes :)
  5. Aug 27, 2010 at 10:53 PM
    IslandBoy71
    Reggie
    Lakewood, CA
    I'm assuming I should use lock tite?
  6. Aug 27, 2010 at 10:54 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    no, dont use locktite
  7. Aug 27, 2010 at 10:54 PM
    chozomo
    Adam
    Vermillion, Alberta
    no on the lock tight
  8. Aug 27, 2010 at 10:56 PM
    IslandBoy71
    Reggie
    Lakewood, CA
    My spidertrax came with a tube of locktite when I got it.
  9. Aug 27, 2010 at 10:56 PM
    RMTacoguy30
    RMTacoguy30 Well-Known Member
    Jay
    Murrells Inlet, SC
    10 DC Prerunner Sport TRD
    EGR in channel Vent Visors, Flowmaster American Thunder Dual Exhaust, Thule ToolBox, AFE Pro Dry Drop In Air Filter, Weathertech Floorliners, TC UCA's, Camburg Spindles, AllPro 3" rear.
    retorque after 50 miles
  10. Aug 27, 2010 at 10:57 PM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
    when i installed my spidertrex wheel spacers they came with locktite. Is there a specific reason to not use the locktite? Also it recommends torque values of 80-90 ft-lbs. I did 85 ft-lbs, similar to my wheel lugs.
  11. Aug 27, 2010 at 11:00 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    i was just always told to torque properly and not use locktite because you dont want those nuts stuck on when you need to take them off. maybe im just paranoid?
