Spidertrax?
Discussion in 'Wheels & Tires' started by knine00, Feb 26, 2012.
  1. Feb 26, 2012 at 12:32 PM
    knine00
    knine00 [OP] Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Can anyone tell me the dimensions of the center bore front lip of a spidertrax spacer. I am not sure my new wheels will fit the outter lip of the spacer. Thanks
  2. Feb 26, 2012 at 12:50 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I believe it is 106mm
  3. Feb 26, 2012 at 12:58 PM
    knine00
    Hudsonville, Mi
    Stock for now
    That is the outside diameter of the lip?
  4. Feb 26, 2012 at 1:00 PM
    KPT
    09 Prerunner
    Yes, it will be the same as the hub diameter. The outer ring keeps the wheel mounting point hubcentric.
  5. Feb 26, 2012 at 1:01 PM
    knine00
    Hudsonville, Mi
    Stock for now
    ok yeah my new wheels are 3" in diameter.
  6. Feb 26, 2012 at 1:01 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Guess I will have to settle for some non hubcentric spacers
  7. Feb 26, 2012 at 1:05 PM
    KPT
    09 Prerunner
    If they have a 3" hub bore then they are Chevy wheels, not Toyota.
  8. Feb 26, 2012 at 1:06 PM
    knine00
    Hudsonville, Mi
    Stock for now
    yeah they are. they came off my old sierra that I sold before I bought the toyota.
  9. Feb 26, 2012 at 1:09 PM
    KPT
    09 Prerunner
    Depending on the width and backspacing of the wheels, adding spacers may cause rubbing on the outer edge of the tire.
  10. Feb 26, 2012 at 1:10 PM
    knine00
    Hudsonville, Mi
    Stock for now
    You seem like an expert. If I were to get you some dimensions would you because to tell me what size spacer would be best?
  11. Feb 26, 2012 at 1:13 PM
    KPT
    09 Prerunner
    If you can give me the tire size, amount of lift, and any numbers stamped on the wheel, we can figure out a plan.
    Also since you are planning on mounting these lug centrically, you should get extended thread lug nuts to be sure the wheel gets centered on the studs.
  12. Feb 26, 2012 at 1:16 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Wheels are 17x9.5 with a 5.5 offset
    I have 285/70r17
    I have 5100 with 885 and LR UCA in the front
    5125 with icon 3 leaf progressive in the rear
  13. Feb 26, 2012 at 1:17 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I was going to go with 1" spacer and know I am going to need to trim a bit
  14. Feb 26, 2012 at 1:21 PM
    KPT
    09 Prerunner
    5.5" backspacing, not offset.
    Yeah this isn't going to work out very well. If you add a 1.25" spacer to get the tires far enough away from the ucas, and to clear the hub ring, that will put the outer edge of those wheels almost 4" further out than stock. That's going to take a lot of cutting and grinding to make it so the tires don't rub the fenders.
    Ideal specs for that setup would be a 4.5" backspaced, 8-9" wide wheel.
  15. Feb 26, 2012 at 2:07 PM
    knine00
    Hudsonville, Mi
    Stock for now
    A 1" spacer will clear the hub ring. I dont see why the 1" spacer wont clear the UCA?
  16. Feb 26, 2012 at 2:08 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Can you run 1" spacer with stock wheels?
  17. Feb 26, 2012 at 2:09 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    He didn't say it wouldn't clear the UCA .
  18. Feb 26, 2012 at 3:18 PM
    knine00
    Hudsonville, Mi
    Stock for now
  19. Feb 26, 2012 at 3:23 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I read the Measuring sticky and I was take my measurements using the outside edges so the wheel must be 17x9 and the backspacing is 5"
  20. Feb 26, 2012 at 3:47 PM
    KPT
    09 Prerunner
    You can't measure the width of a wheel without dismounting the tire. That's why i asked you for the stamped codes on the wheel.
