Spidle lift, stock wheels and 285's?
Discussion in 'Suspension' started by berso, Jun 23, 2011.
  1. Jun 23, 2011 at 10:25 AM
    berso
    berso [OP] Active Member
    Tijuana Mexico
    Black Prerunner TRD sport
    Hi, i have a 08 prerunner DC, it have the 17' wheels as far as i know, you need 4.5 offset wheels in order to fit 285's (33) because of rubing on UCA issues, but also as far as i know, spindles move your tires to a bit to the outside, kinda like an spacer, so i wonder if anyone have tryed this combo....i like the stock look but i want bigger tires....another aproach will be, what spacers will work with 285's and stook wheels, and how much the spindle will push the tire outside....
    Thanks
  2. Jun 23, 2011 at 2:56 PM
    Inked Tacoma
    Inked Tacoma GOT INK?????
    J$
    Central Coast Cal
    08 Prerunner TRD Rugged Trail
    ICON Coil-overs/2.5 V.S. Series Remote Resi Shocks Camburg Spindls'sBall-Joint UCA ( Removed Swaybar) AllPro 3 inch Lift Springs & Flip Kit, KMS XD Enduro 16x8 258/75 Mickey Thompson BAJA ATZ TRD Cat-Back Tint 30% side/Limo in back.
    Ok berso here is what I know the stock wheel will rub on the spindle with that 258 if you don't put on a spacer some say a 1/4 will work fine I curently have the spidertrax 1.25 on mine with stock wheels and have had no issues the stance is great the wheel and 285 dose not stick out that bad I like it. Butt I'm puting new wheels on tommorow with the 4.50 back spacing because my buddy wants my wheels. The pic is with the spacer. stock wheel and a 258/75..Hope this helps you.... And give it some time someone will chime in..... :headbang:
  3. Jun 29, 2011 at 9:14 AM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    damn that's only 1.25" Looks good! Are you going to do anything to the rear or leave it stock?
  4. Jun 30, 2011 at 9:02 PM
    Inked Tacoma
    J$
    Central Coast Cal
    Just added the ALLPRO 3" Leaf sring's two week's ago...Going to do some wheeling with the set up for the frist time on July9th can't waight!!!:D
