Spiker Engineering Ultimate Lift Hood Strut Black Friday Sale!
Discussion in 'Automotive Group Buys' started by SpikerEng, Nov 15, 2021.
  1. Nov 15, 2021 at 6:38 AM
    SpikerEng
    SpikerEng [OP] Well-Known Member
    Leon
    Palos Verdes, CA
    Our Black Friday sale is now underway! All of our 100% USA made products are 15% off during the sale, NOW through 11:59pm November 29.
    Use coupon code "BFTW".
    Our ULTIMATE Lift hood struts are the only ones available for Toyota trucks that offer you the flexibility to have your truck's hood open to any height between stock and up to 8" above stock, for unparalleled access and lighting. Note that you do not have to set your hood at the max height setting - if you have ditch lights, or simply don't need this feature, you can choose whatever height you want, between stock and max. No one else offers this kind of flexibility.
    Spiker kits feature USA made premium OEM-quality struts (black enameled), heavy gauge mounting brackets (powder coated in gloss black), and heavy duty multi-grip rivets. All components in our kits have been designed and sized to work perfectly in your truck, with quality, longevity, and warranty that is the best in the industry.
    3Rd Gen Tacoma:
    2nd Gen Tacoma:
    1st Gen Tacoma:
    Our gauge mounts are designed to hold an Ultragauge or Scangauge securely in your field of view, without obstructing your view of the road. Made of heavy gauge steel with a powder coat finish, these mounts are 100% USA Made, like all our products. Also available is an add-on pod for additional 2-1/16" gauges.
    All Spiker Engineering products are shipped via flat rate shipping of $5.95 within the USA, no matter how many items you buy.
    Follow the links below:
    Spiker Engineering: https://spikerengineering.com/
    '16+ Tacoma Hood Struts - https://spikerengineering.com/product/16+_tacoma
    '95-00 Tacoma Hood Struts - https://spikerengineering.com/product/95-00_tacoma
    '01-04 Tacoma Hood Struts - https://spikerengineering.com/product/01-04_tacoma
    '05-15 Tacoma Hood Struts - https://spikerengineering.com/product/05-15_tacoma
    '96-02 4Runner Hood Struts - https://spikerengineering.com/product/96-02_4runner
    Gauge Mounts - https://spikerengineering.com/product-category/mounts
    hyrule_trd, tacoshell88 and Biscuits like this.
  2. Nov 15, 2021 at 1:12 PM
    dpf88101
    dpf88101 Well-Known Member
    2011 DCSB TRD OffRoad
    6" BDS Lift, Accutune custom valved and tuned Fox 2.5 CO w/DSC & Eibach 700lb Coils, Icon billet UCAs, Fox 2.5 w/DSC Res rear shocks, Custom ALCAN 5" 1000lb Leaf Packs, Archive Garage Hammer Hangers w/crossbar & Stage 4 U bolt flip kit, Brute Force Fab front and rear HC bumper W/SOB FAB Dual Swingouts, Bud Built Skid plates, BAMF LCA Skids, Whiteline LCA Bushings, ES Steering Rack Bushings, Nitro 4.88 gears, ARB lockers, 35x12.50 18 Nitto Trail Grapplers, XD Wheels, engine bay mounted ARB air compressor, WARN X20 10k winch, Uptop Bravo EX Rack, Line-X'd Snugtop Rebel Topper, Cali raised ditch lights, light bar, fog lights Tohashi Grille, HD Headlight Upgrade, Decked Bed System, Katzkin XT Grey and Black two-toned leather interior
    order placed - Thank you
    SpikerEng[OP] likes this.
  3. Nov 15, 2021 at 4:20 PM
    SpikerEng
    Leon
    Palos Verdes, CA
    Thank you - just in time for today's dropoff :thumbsup:.
  4. Nov 15, 2021 at 4:24 PM
    dpf88101
  5. Nov 16, 2021 at 1:03 PM
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    Solid deal! So if install these before getting ditch lights how should I know how high to raise it?
  6. Nov 16, 2021 at 1:51 PM
    SpikerEng
    Leon
    Palos Verdes, CA
    Good question! Ideally you would have the lights in place before installing the hood struts, that will guarantee that you have clearance.
    Having said that, we've never seen ditch lights that interfere at < +4" height, and most can easily accommodate up to +6". Beyond that, I'd suggest either installing the lights first, or checking with someone who has your lights to see how high above stock they can raise the hood.
    Worst case scenario, you can always relocate the hood brackets if you need to change the opening height.
    afgixxer[QUOTED] likes this.
  7. Nov 16, 2021 at 4:26 PM
    EisenWill
    EisenWill Well-Known Member
    Will
    Shenandoah Valley
    2014 TRDOR DCSB
    RCI Aluminum Skids Alu-Cab Explorer Canopy
  8. Nov 17, 2021 at 7:16 AM
    afgixxer
    Tennessee
    Great info! Yeah I don’t have lights yet. Still building it out. Stuff gets expensive. I’m also not sure how I want to do the wiring just yet. To be honest, I was originally going to get the no drill ones but tying it into the ground bolt sounds sketchy. Drilling into my hood just makes me nervous bc I don’t want to screw it up. YouTube always makes things look easier.
    SpikerEng[QUOTED][OP] likes this.
  9. Nov 18, 2021 at 12:31 PM
    SpikerEng
    Leon
    Palos Verdes, CA
    Drilling is not bad, and we give you a drill stopper to avoid drilling too far. Just mark the hole location(s), tap it with a center punch, then drill will a sharp drill bit.
  10. Nov 29, 2021 at 8:40 AM
    SpikerEng
    Leon
    Palos Verdes, CA
    Today is the last day of the sale! It's good to procrastinate, but not to be too late :).
