Spiker Engineering's ULTIMATE Lift Hood Struts Now Available
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpikerEng, Oct 9, 2020.
  1. Oct 9, 2020 at 9:16 AM
    SpikerEng
    SpikerEng [OP] Well-Known Member
    Leon
    Portland, OR
    Spiker Engineering has officially released the ULTIMATE Lift hood struts, the latest version of our original High Lift Hood Struts. They can be purchased directly from our website at https://spikerengineering.com/product/16_tacoma.
    Our ULTIMATE Lift hood struts are designed to open the 3rd Gen Tacoma’s hood to any position between stock prop rod height and up to 8” higher than stock (an increase of 2” over our original High Lift hood struts).
    A unique feature of all Spiker kits is the ability to choose the hood open height during installation. Choose the lower height for low overhead garages (or if you have ditch lights); the maximum height to experience the incredible added light and access; or any position in between to suit your needs. And if you ever decide to change the open hood height, you can relocate the brackets to a new position, without needing to buy a new strut kit.
    Here's a short video of the installation process and the struts in action:
    Our kits come complete with all components needed for installation. Even a drill bit stopper is included, to take the fear out of drilling into your truck. All components are 100% USA made :oldglory:, and covered by a 5 year warranty.
  2. Oct 9, 2020 at 11:00 AM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    Very cool!
  3. Oct 9, 2020 at 7:56 PM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    I have the “last gen” model and it’s one of the best mods I did!! It opens 6” higher than the stock prop. The install is straight forward, took about an hour.
  4. Oct 9, 2020 at 7:58 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    ditto.
    SpikerEng[OP] likes this.
  5. Oct 9, 2020 at 8:20 PM
    Bishop4WD
    Bishop4WD Well-Known Member
    San Diego until I escape Communist California
    2019 MGM Off Road
    I'm installing an air compressor under the hood so I figured these would be a good idea to facilitate the more frequent opening/closing of the hood. Somewhat safer I think, too. Ordered!
    mchertel and SpikerEng[OP] like this.
  6. Oct 9, 2020 at 8:52 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    :popcorn:
    Group Buy maybe?
    anyone care
    SpikerEng[OP], waltuo and deuceb like this.
  7. Oct 9, 2020 at 9:24 PM
    Oregon TRD Off~Road
    Oregon TRD Off~Road Well-Known Member
    Kent
    2017 Tacoma TDR off-road
    One question?
    If you’re running hood ditch lights, will you still be able to get the extra 8 inches of hood space. Or do the lights hit the windshield before you gain the 8 inches?
  8. Oct 10, 2020 at 6:44 AM
    SpikerEng
    Leon
    Portland, OR
    That'll depend on the type of ditch light - some are lower profile than others. Even with the worst offenders you should be able to raise the hood about 4-5" higher than stock, by pushing the ditch lights forward on the brackets:
    With some of the lower profile ditch lights available now, you can probably go the full height.
    With our kits, you can choose the open height to fit your situation - so with ditch lights, you find the height of the hood just before they touch the windshield, and lock that position in during installation. Folks have found this flexibility of our kits to be very useful.
  9. Oct 10, 2020 at 6:51 AM
    SpikerEng
    Leon
    Portland, OR
    Once you get used to having the struts, you'll be shocked when you need to open a "strut-less" hood. It'll feel so "yesterday", having to wrestle with the heavy hood. And the extra height will improve access to the compressor:
  10. Oct 13, 2020 at 8:58 PM
    jerkwithkeyboard
    @SpikerEng
    Any interest in posting a %10 discount code again?
    Maybe get a group buy going again?
    It looks like there are a few that would jump on it.
    Thanks
  11. Oct 13, 2020 at 9:12 PM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    No drilling would’ve be better:(
    Isotrip and shakerhood like this.
  12. Oct 13, 2020 at 9:29 PM
    jerkwithkeyboard
    Flex-tape?
    just kidding
    wahoobie likes this.
  13. Oct 14, 2020 at 4:44 AM
    mchertel
    Mark
    Colorado Springs CO
    You can weld them. Not sure how else it could be done.
  14. Oct 14, 2020 at 6:38 AM
    STrooper
    Jack
    NC
    There is another brand that are bolt on and no drilling. I just wish they were as good quality as OPs!
  15. Oct 14, 2020 at 6:41 AM
    SpikerEng
    Leon
    Portland, OR
    Agreed. But if you are even half-handy, drilling a few holes and touching up the metal with primer/paint is not all that hard, and leads to a nice solid installation.
    McFlysRide likes this.
  16. Oct 14, 2020 at 8:12 AM
    mchertel
    Mark
    Colorado Springs CO
    I guess I am lost on that one. What do they bolt to if there is no holes drilled? I have seen people use those threaded inserts and bolts but the holes for the inserts still need to be drilled. Would have to see a picture I guess..
  17. Oct 14, 2020 at 8:50 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    @SpikerEng I'm thinking this would interfere with the driver side mounting?
  18. Oct 14, 2020 at 9:01 AM
    SpikerEng
    Leon
    Portland, OR
    Hard to tell from this view, it depends on how high it is relative to the black plastic trim piece. The strut will be above the bottom of the plastic trim piece, so if the relay box is below it (or far enough away form the fender) you'll be fine.
    Here's a similar setup that had no interference:
    If you want/need extra space, you can add a couple of spacers to move the mounting bracket slightly away from the fender, like these for a clutch reservoir:
    TailHook[QUOTED] likes this.
  19. Oct 14, 2020 at 9:06 AM
    TailHook
    Alan
    Southern UT
    The SPOD mount looks to be inverted and higher than mine, so I suspect I'll be good. Only one way to find out, right?
    Appreciate the info!
    SpikerEng[QUOTED][OP] likes this.
  20. Oct 15, 2020 at 6:47 AM
    SpikerEng
    Leon
    Portland, OR
    I'm pretty sure you'll be fine as-is. If not, a couple of spacers will help.
    And last but not least, our products come with a money back guarantee, so if you are not 100% happy or have some other issue, you can return it for a full refund :thumbsup:.
