Spiker Engineering's ULTIMATE Lift Hood Struts Now Available
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpikerEng, Oct 9, 2020.
  1. Nov 16, 2020 at 9:20 AM
    #41
    Kruuuzn
    Kruuuzn Well-Known Member
    Randy
    Traverse City, Michigan
    Get 'em while they're hot!!!
    SpikerEng[OP] likes this.
  2. Nov 16, 2020 at 9:53 AM
    #42
    Jyruiz
    Jyruiz Well-Known Member
    Juan
    La Mirada, CA
    2021 DCLB Off-Road 4x4
    Does the drill bit come with the kit?
  3. Nov 16, 2020 at 10:02 AM
    #43
    SpikerEng
    SpikerEng [OP] Well-Known Member
    Leon
    Portland, OR
    It does not, but is available on our website at a nominal cost. A drill bit stopper (to keep from drilling too far) is included in all kits.
  4. Nov 16, 2020 at 10:10 AM
    #44
    Jyruiz
    Juan
    La Mirada, CA
    awesome, thanks, I just placed my order.
    SpikerEng[QUOTED][OP] likes this.
  5. Nov 16, 2020 at 9:57 PM
    #45
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
  6. Nov 17, 2020 at 6:33 AM
    #46
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    just ordered 1 for my 17, and one for my daughters 01. christmas present
  7. Nov 17, 2020 at 7:15 AM
    #47
    WyoRoadDog
    WyoRoadDog Well-Known Member
    2018 TRD OR
    Holy cow! 6 minutes from order confirmation email to shipping notification email! That’s got to be some sort of record!
  8. Nov 17, 2020 at 7:23 AM
    #48
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    A couple of questions for the OP.
    What is the shear strength of the rivets?
    What is the MTTF cycles of the system?
    What is the common failure point? Struts, rivets, truck sheet metal....
  9. Nov 17, 2020 at 7:58 AM
    #49
    SpikerEng
    Leon
    Portland, OR
    No better Christmas present than hood struts, that's very thoughtful of you :thumbsup:.
  10. Nov 17, 2020 at 7:59 AM
    #50
    SpikerEng
    Leon
    Portland, OR
    Thank you, we always strive to get the packages out promptly!
  11. Nov 17, 2020 at 8:06 AM
    #51
    SpikerEng
    Leon
    Portland, OR
    The rivets are rated at about 300 lbf shear strength.
    There is no meaningful MTTF data as there has never been a reported failure. In most cases, a failure in this system would be due to installation error rather than some kind of a systemic or statistically quantifiable effect. Obviously fatigue will take its toll after tens or hundreds of thousands of cycles.
    Again, no failure point has been reported in thousands of installations. Most likely failure mode is installation error, perhaps grossly oversized holes, although the multigrip rivets are designed to accommodate even those situations.
  12. Nov 17, 2020 at 10:45 AM
    #52
    Knute
    So, it is possible to infer that Spiker has not tested the system.
    Relying on anecdotal data as proof the system is robust.
    Thanks.......but no. I'll pass. The hood prop doesn't fail either using the same data base.
  13. Nov 17, 2020 at 10:54 AM
    #53
    SpikerEng
    Leon
    Portland, OR
    No question, for some folks keeping things 100% stock is the right approach. Different strokes for different folks :thumbsup:.
    Bertw192 and davidstacoma like this.
  14. Nov 17, 2020 at 10:59 AM
    #54
    Knute
    I can't justify dropping a C note on something that is not tested.
    I know the OEM stuff has been tested, verified and proven.
  15. Nov 17, 2020 at 11:22 AM
    #55
    SpikerEng
    Leon
    Portland, OR
    To say that our system is not proven is simply incorrect. The forces required have been analyzed, stresses at the mounting locations have been calculated, and fasteners have been selected to provide large safety margin (well above 3X). There has never been a failure to date in the field.
    There are no maintenance items in the kits other than the struts themselves. They have an expected life of greater than 5 years.
    But as I said, based on your comments, you should keep your truck stock and sleep well at night.
  16. Nov 17, 2020 at 11:30 AM
    #56
    Knute
    How many cycles are expected in the 5 year life?????
    5?
    500?
    5000?
    1?
    Calculations are starting point. Testing and verification will prove the design of the system is good.
  17. Nov 17, 2020 at 11:33 AM
    #57
    SpikerEng
    Leon
    Portland, OR
    The life is not cycle related. It is limited by leakage of gas past the seals, which happens regardless of usage. Better struts have better seals, cheaper ones leak within a year or two.
    I don't see the point of continuing this discussion on the forum as I feel that you are just trying to pick a fight. Feel free to start a conversation with me if you have real questions, I'll be happy to discuss.
  18. Nov 17, 2020 at 11:35 AM
    #58
    Knute
    I'm not trying to pick a fight.
    I'm just looking for information so I can spend my $$ with confidence.
    I have 2002 Chevy Trailblazer with gas lifts on the tailgate. The gate is open/closed about 2-3 times each week. The gas struts have not been replaced, still OEM. So, a bit of calculation yields about 3,000 +/- cycles.
    You should have similar data from testing. That is all I'm asking.
  19. Nov 17, 2020 at 11:45 AM
    #59
    SpikerEng
    Leon
    Portland, OR
    Fair enough, I'll take your questions at face value.
    For this strut system, instead talking about MTTF, I'd look at the likely failure modes. The mounting points can fail. The struts can fail. That's about the extent of it.
    The attach points have been designed with a >3X safety factor. Barring an installation problem, they will not fail over any reasonable timeframe.
    The struts are made by an OEM supplier with over 75 years of experience. Toyota gets their struts from similar suppliers.
    That's about it. Lastly, think of the consequence of a failure. It's not like someone is going to get hurt (as if this was a lift kit where something breaks, or a brake upgrade that fails). So the likelihood of any credible failure is minimal, and the consequence is a minor inconvenience.
    BTW, you do know that folks have on occasion knocked the prop rod out of the way when working on the engine, and ended up with the hood landing on their head, right? That's by far the more likely failure mode than with these struts.
    davidstacoma likes this.
  20. Nov 17, 2020 at 11:49 AM
    #60
    PiryongS
    PiryongS Well-Known Member
    Did Chevy provide you with data? Do you have information on their testing process, do you know if they tested those or did Chevy just rely on the sub-contractor to provide the materials? Did The sub-contractor test them? Did you get their data?
    I'm not trying to pick a fight, I'm just looking for how you came about your information regarding the Chevy tailgate and that OEM has been tested, proven or verified.
    GladiatorNOT and davidstacoma like this.
