Spilled gear oil in bed. How to remove?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taylor, Feb 4, 2014.
  1. Feb 4, 2014 at 8:23 PM
    #41
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Break clean is not a safe bet. Most good brakeclean eats paint.
    Degreaser. Simple green. Purple power.
    burntkat likes this.
  2. Feb 4, 2014 at 11:02 PM
    #42
    bk808
    bk808 Well-Known Member
    Brian
    Kaneohe,HI.
    OME lift,882's,10mm top plates,Dakars w/dx6l,ss extended brake lines, LR uca's, poly bushings thru out, PC'd Tundra rims,285-70-17 Goodyear AT's,TG weld on sliders,TG rear bumper,deck plate mod,AFE pro dry filter,Airaid M.I.T., Grillcraft insert,Celica bucket seats,Wet Okole covers,Husky floor mats,Ultragauge,Hi lift jack,LED's on all lights in and out.
    Non- Chlorinated Brake cleaner is safe as long as you don't let it sit on your paint. I spray it on a clean terry cloth to remove tar and hard to remove crap from my paint
    never had a problem or damage to the finish at all. But in your case,for what you want to do the biodegradable citrus cleaner or simple green (and a lot of scrubbing)a few times is a better option.
  3. Feb 5, 2014 at 6:19 AM
    #43
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    12$
  4. Feb 5, 2014 at 8:51 AM
    #44
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    For like 6 ounces
  5. Feb 5, 2014 at 8:54 AM
    #45
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Dawn, and a product in cleaning section called Bar Keepers Friend, its a powder put it everywhere and scrub then Dawn again
  6. Feb 5, 2014 at 12:28 PM
    #46
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    last time i did this (exact same situation) i cleaned most up with cat litter, then headed to the local coinop car wash and hit it with the soapy shit and hot high pressure water.
  7. Feb 5, 2014 at 12:29 PM
    #47
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    :rolleyes:
  8. Feb 5, 2014 at 12:35 PM
    #48
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    i used to do plumbing and would have to take this giant threading machine in the back of my truck and the oil pan for that thing would spill every time... any soap that cuts grease should work decently. but just plain water won't do much. most of the time i would just wipe up the oil with a dirty rag and id just leave the stuff i couldn't get and it would always just go away eventually.
  9. Feb 7, 2014 at 9:19 AM
    #49
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Since I haven't had a chance to get to it, this is basically what I'm doing, haha.
  10. Feb 7, 2014 at 4:22 PM
    #50
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    x2 but I just used Simple Green and a brush. Brush down the bed real good and it'll look like new again. And then a week later it'll look dirty again :( if you abuse it like I do mine
