Spindle install and popping sounds
Discussion in 'Suspension' started by TacomaDawg23, Apr 11, 2013.
  1. Apr 11, 2013 at 8:50 PM
    TacomaDawg23
    TacomaDawg23 [OP] Member
    Charles
    Georgia
    12 DC PreRunner TRD
    I have read some referring to awful popping noises coming from their front end after installing spindles. Has the cause been determined yet? Mine are on the way and wanted to see if I needed to do anything during install. Truck has 9,000 miles on it so want to make sure I do it right.
  2. Apr 14, 2013 at 7:29 PM
    TacomaDawg23
    Charles
    Georgia
    12 DC PreRunner TRD
  3. Apr 14, 2013 at 7:41 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Your stock spindles are within OEM spec, and lift spindles are much longer. The extra length is causing your LCA bushings to pop back and forth as you brake and accelerate. My 07 did the same thing after installing spindles. I haven't seen a fix for it, not sure if there is one. I ended up selling the truck before the bushing wore out.
