Spindle interchangeability
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cash0820, Apr 24, 2021.
  1. Feb 23, 2024 at 12:05 PM
    NotThatCarGuy_88
    NotThatCarGuy_88 New Member
    Robert
    2006 pre runner
    U-joints, carrier bearing, alternator, and fan belt.
  2. Jan 11, 2025 at 10:12 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Tried searching, are Prerunner spindles compatible with 4wd? Looks like there just a dust cap on the back, but looks like the hub center is the same, center is capped where the cv would go through?
    Anyone ever converted one?
    To be clear, I want to press out all the guts to press in new bearings and a new manual cv hub, used spindles have become very expensive on eBay, found prerunner spindles for significantly less
  3. Jan 11, 2025 at 10:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep.
    Perfect in your case since you're pressing everything out.
    Differences are listed in the first page.
  4. Jan 11, 2025 at 10:30 PM
    Laxtoy
    Maltby, WA
    Nice, thank you
