Spindle lift advice! (With poll)
Discussion in 'Suspension' started by machotaco2012, Aug 11, 2016.
Which would you do?
  1. Stock bilstein shocks with block
    0 vote(s)
    0.0%
  2. New bilstein 5100 shock (extra $$)
    2 vote(s)
    100.0%
  1. Aug 11, 2016 at 7:54 PM
    machotaco2012
    machotaco2012 [OP] Well-Known Member
    •3” front blocks •2” steel rear blocks •1.25" spidertrax spacers for clearance •285/70/17 (33's) Ko2's •20% tint
    Hey looking to get a maxtrac spindle lift. Im deciding whether to keep my shocks and add a small block with the spindles or just get new shocks. My truck has stock bilstein shocks. Is it worth the extra money to get the new extended shocks or should i just go with the blocks? It cost about 150 more :( but if absolutely neccessary... And yes I do have a prerunner.
  2. Aug 12, 2016 at 9:01 PM
    darkstar187
    darkstar187 Member
    I would go with an add a leaf or new rear leaf springs. before installing new shocks. depending on how much rear lift you are doing you may or may not need shocks. Bilstein 5100 are a great option. If your shocks are worn you would be better off replacing.
