Spindle lift back to stock ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tommyhd03, May 1, 2020.
  1. May 1, 2020 at 9:20 AM
    tommyhd03
    tommyhd03 [OP] Well-Known Member
    tommy
    spartanburg
    Sport Tacoma double cab long bed
    885 coils, blistein 5100 front and rear, 1 1/2 AAL. SCSI sr8 wheels, 285/70/17 cooper discover at3 tires.
    Friend of mine has a 14 Tacoma with spindle lift and 4 inch block in back. He hates the ride but got a smoking deal on truck.
    I believe the lift is a rough country 6 inch spindle lift with dropped crossmember. Is there a way to make this thing have a 3 inch lift without modding crossmember. He wants a 3 inch lift with 33s. If we have to keep the lift what front shocks will work with spindles?
    Gonna do an all pro leaf back in rear with icon rear suspension. I need help for the front setup.
  2. May 1, 2020 at 9:28 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If your friend's truck is currently on big spacers in the front, he can change to struts sized for the 6" lift: https://www.roughcountry.com/premium-n3-lifted-strut-500080.html?find=2005-toyota-tacoma-4wd-565331
    High-end coilovers from Icon, King, Fox, etc. are available for 6" lift as well, but I doubt ride will improve on pavement compared to what he has now (may well get rougher).
    Note: Rough Country makes both a 4" drop-bracket lift and a 6" drop-bracket lift. Be certain which one he has. AFAIK there are no struts or coilovers available for the 4" drop-bracket lift.
    whatstcp likes this.
  3. May 1, 2020 at 9:38 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    If the truck is 4wd you are stuck with it
  4. May 4, 2020 at 12:45 PM
    tommyhd03
    tommy
    spartanburg
    Truck is a 2wd
  5. May 4, 2020 at 1:01 PM
    anthony250f
    Anthony
    San Diego, CA
    Then fairly easy
  6. May 5, 2020 at 8:21 AM
    tommyhd03
    tommy
    spartanburg
    Does it require welding crossmember back in?
  7. May 5, 2020 at 8:36 AM
    anthony250f
    Anthony
    San Diego, CA
    Shouldn’t have to. With 2wd you are not suppose to cut the crossmember, however I have seen shops do it anyways lol
  8. May 7, 2020 at 4:49 PM
    tommyhd03
    tommy
    spartanburg
    Appreciate the help. Truck doesn’t have crossmembers cut. I just need to find stock spindles now.
