Spindle lift do any good for bolt on LT ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by killerdawlphin, Mar 16, 2021.
  1. Mar 16, 2021 at 1:23 PM
    killerdawlphin
    killerdawlphin [OP] Active Member
    07 5.7 Tundra 4x4 regular cab
    Pro comp 6" lift
    I have a 2010 Prerunner. I bought it with a 6inch lift spindle. I don't want the truck at 6" high since I want to slowly buy a bolt on LT suspension. Should I get the stock spindles or buy a 3"inch lift spindle.
    If i get a stock i probably would purchase the baja gusset kit to weld it on.
  2. Mar 16, 2021 at 2:20 PM
    sistare44
    sistare44 Member
    Fort Jackson, SC
    2010 Sport DCLB PreRunner - Timberland Mica
    Not positive but fairly certain that the lift spindles only come in 4" length. It's either 4" or add a spacer on top of coil to make it 6" total. Either way, stock spindle with a gusset sounds like the height you are looking for.
  3. Mar 17, 2021 at 8:19 AM
    killerdawlphin
    Pro comp 6" lift
    Haha dang i didn't know that and i wish I knew that earlier. But anyway, thank you sounds good. In that case I'll go to the junkyard and find me some OEM spindles
