Spindle Lift Question
Discussion in 'Suspension' started by agaona, May 9, 2011.
  1. May 9, 2011 at 7:44 AM
    agaona
    agaona [OP] Member
    Adrian
    Laredo
    13 Tacoma Texas Edition 4x4
    3" nitro lift by pro comp
    Hello, what is the most lift I can get with a spindle lift since I have a 2wd prerunner? Someone stated that I could probably get a 6'' lift with spindles......Let me know.
    Thanks
  2. May 9, 2011 at 7:47 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Spindles will give you 3.5" of lift by themselves. If you swap out your coilovers you can get another 2.5", but with that you'll also want to replace your upper control arms to get the alignment under control.
    What are your plans for the back?
  3. May 9, 2011 at 7:53 AM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    I think the Camburg spindles are 4" spindles. Total Chaos are 3.5".
  4. May 12, 2011 at 11:13 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    They need to start making them for us 1st gen guys! Dang what's taking them so long don't they see all of the LT guys with 1st gens?
