Spindle lift question
Discussion in 'Suspension' started by Greywolf, Jun 10, 2011.
  1. Jun 10, 2011 at 6:19 PM
    Greywolf
    Greywolf [OP] Well-Known Member
    mike
    Virginia Beach, Virginia
    2011 Prerunner MGM Grey
    undercover tonneau color matched, wet okole seatcovers, n-fab step bars, AMP research bedstep, Maxtrac Spindles with toytec 3" ULK. 285-70-16 toyos and Fuel Throttle wheels
    I have read a lot on here lately and I really haven't found aan answer to the question can you use the stock shocks with the 4" spindles and will the rear shocks be long enough or should they be replaced. Also how will it look with stock 265-65-17 tires.:confused:
  2. Jun 10, 2011 at 8:20 PM
    Inked Tacoma
    Inked Tacoma GOT INK?????
    Jeremy
    Central Coast Cal
    2019 Tacoma TRD Sport DCLB
    2019 Tacoma TRD Sport DCLB De-Badged, Tent done Coming soon Bilstein set at 2 inch fronts rear 1.5 AAL 17 inch wheels and 265 BFG AT..... Speaker replacement sub and amp and of course window tent! Gone but not forgotten 08 Prerunner TRD Rugged Trail ICON Coil-overs/2.5 V.S. Series Remote Resi Shocks ICON Uni-Ball arms Camburg lift spindles ( Removed Swaybar) Dever 3 inch Lift Springs & Flip Kit, KMS XD Enduro 16x8 258/75 Mickey Thompson BAJA ATZ TRD Cat-Back Tint 30% side/Limo in back. The one that started it all 1999 Tacoma Preunner 6 inch Fabtech drop-bracket with custom kings all the way around AllPro 5 inch springs 35's custom paint and one bitch-en Alpine seystem for sound!!!
    As far as I can tell on the Spindles you can use your front stock coilovers. Some guys on here up grade to the bilstiens and set them at .0 or .85 and like the look and love the ride I'm installing my Spindles tomorow and I have ICONS that I will set at .5-1 inch....As far as the rear go's with the add a leaf yes new shock's are a must... Other pepole will chime in on this and if I'm wrong about the front they will let us know.. Look around for the show off your spindle thread lot's of pic's of diferent set up's and yes in my opion 265's will look small with that much lift....http://www.tacomaworld.com/forum/suspension/131402-show-off-your-spindle-lifts.html
  3. Jun 10, 2011 at 8:25 PM
    kingtaco
    kingtaco Well-Known Member
    San Gabriel Valley
    Yes you can. I upgraded to the 5100's but it wasn't necessary. You don't have to do anything to the rear. You will have a slight "bro" lean though.
  4. Jun 10, 2011 at 8:25 PM
    mitchell4655
    mitchell4655 Member
    mitchell
    ft myer VA
    2011 taco TX PRO
    camburg 4in spindle lift, falken tires, billet grill
    my tacoma right after camburg 4 in spinlde
  5. Jun 11, 2011 at 5:12 AM
    Greywolf
    mike
    I know I should upgrade the shocks but I can only afford one or the other so I would like to go with the spindles and bigger tires. then save for the shocks. maybe I will buy an billes and then save for the spindles. Thanks guys.
