Spindle lift question
Discussion in 'Suspension' started by matt74, Apr 12, 2013.
  1. Apr 12, 2013 at 8:25 AM
    matt74
    matt74 [OP] Member
    TRD
    Ok i dont know much about lifts but i did some research and i think im ready to ask my questions. so I'm thinking about getting a 4" max trac spindle lift on my prerunner and was wondering will I have to buy any additional parts for the front or will I just be fine buying the $500 spindles and be done with the front? And also if I do the aal for the rear will it lift it enough to make it even or do I hav to buy shocks or put a block for the rear or somethin. I'm fine with the front being a little higher too. Thanks
  2. Apr 12, 2013 at 8:28 AM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    You are all good to go when you buy the spindles (I have the spindles). An AAL will still have some bro lean, but its not terrible. Im sure adding a block would put you level.
    You can kind of tell right here, that there was a slight lean with the AAL.
  3. Apr 12, 2013 at 4:09 PM
    matt74
    matt74 [OP] Member
    TRD
    And that's only adding one leaf? And using your existing u bolts? I'm just trying to figure everything out and general pricing, u spent like $90 for one leaf in the rear? Not counting installation And thats it? Also wat size tire do most people go with after spindle lift? will i need wheel spacers too for aftermarket rims? Thank you!!!!sorry about all the questions, those are my last ones I promise ha
  4. Apr 12, 2013 at 6:54 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Usually people do a 33" or 32". I Currently have 31" (pussy shit). I got my AAL for free from a very generous member and he even helped me with the install. Yes we used stock u-bolts and had absolutely no problem. Hopefully I answered about everything. Feel free to ask everything you need!
  5. Apr 12, 2013 at 7:06 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    12 Tacoma Prerunner TRD
    E&G Grill, Alpine MRX-F65 Amp, Alpine SWS-10D4 Sub, Image Dynamics CTX65cs component speakers, BHLM, TRS Bi-xenon Morimoto Mini Stage III Kit (D2S)with Halo's, LED's Fog, parking, DRL and License Plate , ProComp Wheel Series 7089, Hankook AT 315/75/16, Total Chaos Stock Length LCA, Icon 2.5 Extended Coilover Resi's, Icon Tubular UCA's, Icon 2.0 Rear Resi's, Maxtrac Spindles 4 inch lift, OME Dakar Leafs w/D29xl extra Leaf, AP U-bolt Flip Kit, Extended Brakelines, Pelfreybilt Front Plate Bumper, Pelfreybilt Rear HC Bumper, Pelfreybilt IFS Skid, Pelfreybilt Mid Skid, Rigid Industries 20" LED lightbar, BAMF Behind the Grill Lightbar, Relentless Bed CrossBars, Yukon 4.56 Gear's
    I think if you go with the spindles and a 2 inch AAL it would put you pretty close to level maybe a touch nose high. You do not need to buy anything else for the front the stock shocks and springs will be fine if you want to save the money.
    If you check out my build thread you can see my truck with 5100's at 1.75 and stock leaf springs. Next would be my Maxtrac spindle lift with the 5100's set at .85 and Dakar leafs in the rear. There are pics of it with 265/70/16's and 285/75/16 tires on also.
  6. Dec 16, 2013 at 7:05 PM
    SpeedwayBlueAlex
    SpeedwayBlueAlex Well-Known Member
    Alex
    Modesto
    SWB 4x4 TRD OFF-ROAD 6-SPEED
    I just ordered my 5100s 1.6 eibach springs and maxtrac 4 inch spindle lift. Now my question is will I need a aftermarket UCA or should I be fine ? I dont do much offroading if that helps thanks!
  7. Dec 17, 2013 at 11:11 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    You won't need them with the additional 1.6" lift from the eibachs.
  8. Dec 17, 2013 at 8:02 PM
    SpeedwayBlueAlex
    Alex
    Modesto
    No as in UCA's right ?? Thanks
  9. Dec 17, 2013 at 8:09 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Correct... you will not need the Upper Control Arms based on what your are doing.
  10. Dec 18, 2013 at 9:52 PM
    SpeedwayBlueAlex
    Alex
    Modesto
    Thanks ill post a pic of my taco when my spindles get here next week ! Eibachs and billys are already here thanks to DownSouthMotorsports with the fast shipping
  11. Dec 28, 2013 at 6:05 PM
    SpeedwayBlueAlex
    Alex
    Modesto
    Wondering u could help a former member out ! I have 2nd gen 06 prerunner I just ordered my 4 inch maxtrac spindle. Gonna run the eibachs and billy 5100 also. My question is will my spindle fit with my 285/75/16 on 16x8 rims. Have no knowledge when it comes to offset but the website I ordered my rims from says my rims have a backspacing of 4 inches and offset -12 mm bore diameter is 4.25 ? Would greatly appreciate the help!
