spindle lift vs no spindle
Discussion in 'Suspension' started by shooter3225, Nov 17, 2013.
  1. Nov 17, 2013 at 1:14 AM
    shooter3225
    shooter3225 [OP] Well-Known Member
    Tyler
    Riverside, CA
    09 TRD PreRunner
    I'm going king 2.5s all the way around with tc uca's. I'm wondering if going the spindle route which is 4" or 3.5" if I go tc, is the best option if I'm trying to be level. I'm gonna be running 33s and I want to be level and have good ride quality in the back.
    What leaf pack or aal would be recommended to be level with a spindle lift? Or should I just forget the spindle lift does it really do anything for performance?...Normally don't have a load in the bed but will fill it a couple times a month when going to the desert or something.
  2. Nov 17, 2013 at 1:18 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Spindle does nothing for performance, it basically keeps the suspension geometry and ride stock (as long as you have stock suspension components except the spindles)
  3. Nov 17, 2013 at 8:41 AM
    shooter3225
    Tyler
    Riverside, CA
    09 TRD PreRunner
    But having spindles and lowering the preload on your c/o's does that improve performance of road or general ride quality? Or is it better to just run the kings at 2.5
  4. Nov 17, 2013 at 10:31 AM
    95 taco
    95 taco Battle Born
    I'm not sure on that, i have no experience with coil overs, but in theory, yes, it'll ride a little smoother/better.
  5. Nov 17, 2013 at 1:44 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Run the kings with the spindles and have no preload. Much better ride, I know from personal experience
  6. Nov 17, 2013 at 1:45 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^ What he said. Spindles will give you lift without sacrificing on road ride quality. I got rid of almost all of my preload....make sure to leave a little bit of preload on driver's side ( I didn't, Doh!) for your Taco lean
  7. Nov 17, 2013 at 1:55 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Same here, it improves your ride and you get a lift.
  8. Nov 17, 2013 at 4:36 PM
    VolcomTacoma
    Jeff
    NorCal
    Hey hey watch what you're saying. The spindle alone does not improve your ride. If you had previous lift, 2"-3", most likely it was from preloading your coils...adding the spindle merely provides lift, NOTHING ELSE. An after effect is if you are happy with the 3"+ lift you can relax the prload on your coils and yes, you will have a happier ride.
    Just don't want to confuse anyone thinking spindles will make the ride better. I was pulling like 6" of lift with spindles and preloaded coils, but the ride was exactly the same as pre-spindle lift, i just sat alot higher
  9. Nov 17, 2013 at 4:58 PM
    shooter3225
    Tyler
    Riverside, CA
    09 TRD PreRunner
    Okay so if I go spindle then I don't have to have any preload on my kings which will be a better ride, but what should I do in the back to keep it level? Icon progressive aal or a full dakar pack? I want to to be level but still have good ride quality in the back.
  10. Nov 17, 2013 at 5:37 PM
    VolcomTacoma
    Jeff
    NorCal
    I went with all pro expo pack and I was pretty level with maxtrac 4" spindles up front. Without any weight in the back I'm definitely a little ass high. With 2 spares and a big ass box full of dirt and rocks(a good 250+ lbs) Its almost perfectly level
