Spindle lift
Discussion in 'Suspension' started by mxmaniac, Oct 4, 2009.
  1. Oct 4, 2009 at 9:55 PM
    mxmaniac
    mxmaniac [OP] Member
    Tyler
    chino hills
    05 PreRunner
    Donahoe coil overs (set at 1") ,Camberg spindles, Camberg UCA, OME Dakar leaf pack, Bilstein 5100.
    Hey guys
    I have donahoe coilovers and camberg uca right now on my truck. I just ordered camberg spindles and ome Dakar leaf pack. i was just wondering if it was easy to install the spindles. iv installed everything so far so i dont think this will be a problem.
    thx for the help
  2. Oct 4, 2009 at 9:58 PM
    TR3NT
    TR3NT saving up
    So Cal
    White 09 PreRunner SR5 Double Cab
    recessed billet, blacked out valence,cheaters lrgm, 5100's all around, painted rims, weathertechs, painted pinch weld, 33" Hankook m/t, mkw wheels, tsb leafs
    im pretty sure its not easy, but you could give it a shot. I think 06Bluez did them himself, so you can pm him
  3. Oct 4, 2009 at 11:56 PM
    Kenny650
    Kenny650 Well-Known Member
    It's not an easy task. That's why I didn't even bother installing them myself. You have to bleed the brakes, replace the brakes, and all of this other bullshit. I suggest paying someone to do it for you.
  4. Oct 5, 2009 at 4:05 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    you have to replace the brakes? stupid question but what do you mean by that?
  5. Oct 5, 2009 at 4:10 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's all bolt-on stuff. Piece of cake if you've done coilovers and UCAs already.
    Pull the wheel, pull the brake caliper (no need to undo the line unless you're replacing the brake lines), pull the caliper mount, unbolt the steering linkage, unbolt the UCA from the stock spindle, unbolt the spindle from the LCA, move bearing and stuff to the new spindle as needed, reinstall in reverse.
    Do x2 and get an alignment. Nice afternoon job with time for beer and pizza.
  6. Oct 5, 2009 at 4:12 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    I think your supposed to install extended brakelines with the spindle, at least that's what I was told/did.
  7. Oct 5, 2009 at 4:17 PM
    08pretaco
    az
    oh so your not replacing the brakes, as in new different parts. he meant that you take the brakes off then put them back on...of course youd have to do that haha my bad just read it wrong
  8. Oct 5, 2009 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo.
  9. Oct 5, 2009 at 5:49 PM
    mxmaniac
    Tyler
    chino hills
    05 PreRunner
    well i think i might have someone do it now. i really dont have time to put everything on.
    i still haven't bought brake line and it didn't come with my spindles, iv looked around but couldn't find extended front brake lines. where do i buy them?
    Thanks
  10. Oct 5, 2009 at 10:50 PM
    Kenny650
    sorry I meant to say brake lines
  11. Oct 5, 2009 at 10:53 PM
    Kenny650
    You missed the most hardest part of the whole project: grinding the calipers. :)
  12. Oct 6, 2009 at 7:12 AM
    mjp2
    NJ
    Call Camburg. They've got a set that they include with their long travel kit that will work perfectly.
    I embrace any chance to throw sparks halfway across the garage. :D
  13. Oct 6, 2009 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah...yes..... The smell of burning metal. Nothing gets the 'ol adreanalin flowing better than some hot sparks, and a small fire in the garage... :)
  14. Oct 6, 2009 at 8:03 AM
    08pretaco
    az
    you have to grind the calipers :eek:
  15. Oct 6, 2009 at 8:47 AM
    mjp2
    NJ
    People shouldn't shy away from the easy stuff. Seriously, give one of these projects a shot and you'll be amazed how much confidence it builds.
    It's like folks who go to a shop for brake work because they prefer to have it done by a "professional." It's a damn important system, which is EXACTLY why I do brake work myself. Nobody will put as much care and attention to detail into my truck as I will.
    Replacing brake lines takes 10 minutes and bleeding brakes takes a 10mm box wrench and someone sitting in the driver's seat. Get some wrenches and start turning them!
  16. Oct 6, 2009 at 8:49 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2!
