Spindle lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by PnoyBOS5, May 25, 2010.
  1. May 25, 2010 at 9:53 PM
    PnoyBOS5
    PnoyBOS5 [OP] Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    Hey everyone,
    Well I decided i need a lift and i am going to get this http://performancelifts.com/cgi-bin/cart/FTS41307.html
    but i want to clarify some things,
    i can buy the spindle lift for 389 for spindles only. but it is good to replace front shocks so i added a pair for 90 bucks. and then it says i should also do the rear, however i dont care i like the bro lean look, so i can skip out on it for now right?
    so in total im going to get the 3'' SPINDLES , & FRONT END SHOCKS then i am good to go or am i missing something?
    thank you all.
  2. May 26, 2010 at 7:45 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    if you order just the rear shocks, your susp in the rear will not change. the truck will still have some bro lean to it.
    seeing that your truck is a 97, it could prob use some new shocks on all 4 corners. if you got the extra $100 i'd get the rear shocks too
  3. May 26, 2010 at 10:57 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I thaught with spindle lifts you needed to get extended brake lines??? But not 100%sure on that....
  4. May 26, 2010 at 11:08 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thats not fair, spindles for my truck start at like 900 bucks :(
  5. May 26, 2010 at 8:52 PM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    muhahh thanks to all especially nelson, you were there last time i posted lifts back in february... so yes this will work out the lift?
  6. May 26, 2010 at 9:56 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  7. May 26, 2010 at 10:10 PM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    good looking out thanks, they dont offer new front shocks only spindles? cuz id like to get new front shocks as well
  8. May 27, 2010 at 2:29 PM
    MadTaco461
    CA
    Kinda stock
    Check out offroadwarehouse, I'm not sure what brand of OE shocks you are looking for.
  9. May 27, 2010 at 2:33 PM
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    I've heard and believe nothing good about fabtech. Spend some extra cash and get something thats worth talking about.
  10. May 27, 2010 at 2:48 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    x2, fabtech is for street queens.
    Definitely go with these spindles much stronger they are plated and not casted like fabtech.
    Edit** they are also casted but they are still a better spindle than fabtech
  11. May 27, 2010 at 2:55 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Thats 1...
  12. May 27, 2010 at 3:47 PM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    ok so if i go with doetsch spindles , i should still get new shocks right?
  13. May 27, 2010 at 4:36 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    yes, no matter what route you go you should replace all 4 shocks. just because they are probably all spent and have no life left in them
  14. May 27, 2010 at 5:01 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    x2. You dont want to run a nice, new lift with shitty, worn shocks. And you definitely wouln't want to run just 2 new shocks.
  15. May 27, 2010 at 5:20 PM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    great thanks!
  16. May 28, 2010 at 5:02 PM
    MadTaco461
    CA
    Kinda stock
    yeah do new shocks for sure on all 4. You'll regret if you don't
  17. May 29, 2010 at 10:26 AM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    great most definately going for 4 new shocks, in the future i plan on lifting the rear. why do shackles cost most than adding a leaf?? also which one of those should i get?
    AAL or Shackles? which one is easier as well hehe thanks
  18. May 29, 2010 at 9:44 PM
    MadTaco461
    CA
    Kinda stock
    go for an add a leaf in the rear. You will get a good ride outta that
  19. May 29, 2010 at 10:03 PM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    oh for real? i was reading it said stiffer ride, none the less . i am open to opininons
  20. May 29, 2010 at 10:20 PM
    MadTaco461
    CA
    Kinda stock
    It will be a bit firmer because you are adding force to the springs. It's not going to be crazy stiff where your rear would hop. What type of driving are you mostly using your truck for?
