spindle setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Nov 26, 2009.
  1. Nov 26, 2009 at 8:26 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Does this sound good.
    1.camburg spindles with brake lines
    2. 2'' aal
    3with stock suspension will this work.
  2. Nov 26, 2009 at 8:28 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Its a start :thumbsup: but you may want longer travel shocks with those spindles...4" on your stock shocks may cause unwanted stress
  3. Nov 26, 2009 at 8:31 PM
    kinkrider101
    santa barbara
    wheels and tires
    i want to run the toytecs with them set to 1''
  4. Nov 26, 2009 at 8:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Spindles are designed to work with OEM length shocks.
  5. Nov 26, 2009 at 8:33 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Id recommend getting 5100 since your gonna be tearing into there. Also since your doing spindles and it sounds like you got some decent money, id pass on the 2" aal and get some alcan or dakar leafs for the back. Reasons: reduces axle wrap, much better ride, quality than an aal. Also go with 5100 for the back or possibly a set of 5125 with extended brake lines. Contact downsouth motorsports and they will tell you which would be a better option for the back.
    Ultimately the ideal I think would be a nice set of coilovers, sway away, fox, toytec, icons for the front to match those camburgs :thumbsup:
  6. Nov 26, 2009 at 8:33 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  7. Nov 26, 2009 at 8:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A lift spindle isnt a long travle set up. Spindles still retain the use of the OEM upper, and lower CA's.
  8. Nov 26, 2009 at 8:37 PM
    08pretaco
    Oliver
    az
    Then they make a set of coilover he can run them with. Some reason I don't like camburg c/o and idk know why so don't ask lol :) just prefeence
  9. Nov 26, 2009 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Camburgs are basically a Re branded Sway-A-way.
  10. Nov 26, 2009 at 8:38 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    true, but they are often used in with LT set ups because the stock spindle is relatively weak. Engage also has a spindle for their LT kit
  11. Nov 26, 2009 at 8:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. But, a long travel is achieved with different U/LCAs....OP didnt list that as an option. Useing extended travle Co's with a spindle, can lead to blowing out the Upper, and possibly lower, ball joints. Unless you use limiting straps, but then, you have to limit them to a stock length.
  12. Nov 26, 2009 at 8:46 PM
    kinkrider101
    santa barbara
    wheels and tires
    thanks for the info
  13. Nov 26, 2009 at 8:49 PM
    08pretaco
    Oliver
    az
    conclusion: yes they will work with stock suspension, yes the 2" aal will work.
    im so damn anxious to get my damn camburg spindles and c/o on already F***
  14. Nov 26, 2009 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should consider longer shocks for the rear with the set up you are wanting, but the front will be fine.
  15. Nov 26, 2009 at 8:51 PM
    08pretaco
    Oliver
    az
    yay 5125's just call downsouth they will hook you up!
  16. Nov 26, 2009 at 8:57 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    on our stock arms?
  17. Nov 26, 2009 at 9:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. You need at least different UCAs that allow for the extra travle of extended travle Cos.
  18. Nov 26, 2009 at 9:10 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    yes, you keep stating that you need longer shocks (you dont) so chris was telling you what would happen if you used longer shocks on our OEM setup like you kept saying...
  19. Nov 26, 2009 at 9:11 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ hmmm if extended c/o's can damage uniball joints then why would camburg off their spindle with their mid travel kit without recommending limiting straps?
  20. Nov 26, 2009 at 9:12 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I said you might want to consider running extended c/o's, not that he needed. it was just a recommendation. IIRC, most members run mid travel c/o's with their spindles without limiting straps, along with uniball UCAs
