Spindle won’t rotate anymore to uca.
Discussion in 'Suspension' started by Darren.clark, Sep 14, 2022.
  1. Sep 14, 2022 at 1:02 PM
    Darren.clark
    Darren.clark [OP] Member
    Cement 2018 trd sport
    Here is a video at outlining exactly what I’m dealing with.
    https://youtu.be/8qPj8X8UFBM
    Installed new strut assembly. Trying to align the spindle with the upper control arm to tighten everything back together. Spindle no longer snapped back or rotates backwards towards upper control arm. It used to. I used to be able to maneuver the spindle around and it would align with the ball joint of the upper control arm but it no longer aligns. Can rotate spindle front to back but not backwards towards the engine.
  2. Sep 14, 2022 at 1:04 PM
    Darren.clark
    2018 trd sport
  3. Sep 14, 2022 at 1:12 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Pull the UCA down, and check to see if the cv axle came apart internally in the middle - usually just requires a little wiggling and finessing to pop back in place - common if you just let the lca dangle too far down without affixing it from moving.
    EDIT:
    This was the fix. :thumbsup:
    Crikeymike and Superdave1.0 like this.
  4. Sep 14, 2022 at 1:15 PM
    Darren.clark
    I’m on it. Thanks man. I’m scared sh1tless because I’ve never screwed with a cv before.
    drizzoh likes this.
  5. Sep 14, 2022 at 1:16 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    It's the cv. The part attached to the diff, inside the boot isn't aligned correctly
    Crikeymike and zippsub9 like this.
  6. Sep 14, 2022 at 1:22 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I agree with this perspective as well. The inner tripod rollers will drop out of the tulip and need to be set back in as well sometimes when it is left hanging.
  7. Sep 14, 2022 at 1:23 PM
    Darren.clark
    Fixed! Thanks guys! You guys are gods amongst men!
    JFriday1 and drizzoh like this.
  8. Sep 14, 2022 at 1:24 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Np. I'm used to it from lowering an excessive amount of FWD cars. Once it pops back in you should be good to go.
  9. Sep 25, 2022 at 12:20 PM
    Big Red 2nd Gen
    Big Red 2nd Gen Well-Known Member
    Dan
    Red 2008 TRD Access Cab 6 Speed
    TRD Cold Air Intake, Fat Bob's Vated Bilstein fronts set at 3 inches, stock rear leafs with ICON progressive multi leaf "add a leaf", MBRP Stainless dual exhaust, Sport Hood with scoop, Pedal Commander, Pro Comp 16x8 wheels with 265/75R16 KO2's, toneau cover.
    CV joint came apart far enough that it binds or further to where the spider pops out. Get all that lined up again and you'll be golden. Prob pulled the spindle out further than you needed to for clearance to get the shock and spring in. Common problem.
