Spindle would this setup work?
Discussion in 'Suspension' started by FixedTRD, Nov 9, 2010.
  1. Nov 9, 2010 at 11:39 PM
    FixedTRD
    FixedTRD [OP] Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    I almost saved enough for spindle my question is would my wheel setup work with it. I have been reading some post where the wheel setup would not work. I have atx artillery 17x9 -12mm offset tires are going to be hankook MT 285/70/17 which is going to get mounted this week. I want to make sure they will clear before I order the spindle.
  2. Nov 10, 2010 at 12:11 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    What is 12mm offset? Maybe I don't understand metric offsets but I believe 4.5" offset is needed to clear spindles.
  3. Nov 10, 2010 at 12:22 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Maybe you are reffering to backspacing at 4.5.
    Backspacing and off set are two seperate things. Offset is the bolthole flange in relation to the center of the wheel. Backspacing is the bolt hole flange measured from the lip of the backside of the rim to the bolt hole flange.
    For instance. If a rim is 10 inches wide and the bolt hole flange is directly in the center of the rim then it should be 0 offset with 5 inches of backspacing.
    Someone correct me if i'm wrong.
  4. Nov 10, 2010 at 12:45 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    I guess I got tripped up in the terminology. I guess you would say my rims have a 4.5" "backspacing". So to the OP, a 17x9 with 0 offset would be 4.50" back spacing. Now if there's a 12mm offset I think that would mean you have closer to 5" of backspacing. That's cutting it close...
    hmm I'm not sure if that sounds right but I know the higher the number the closer the tire will be to your spindle. Can't explain any better unfortunately.
  5. Nov 10, 2010 at 5:58 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    A 9" rim with 0 offset is 5" backspaced.
    A 9" rim with -12 offset is 4.5" backspaced.
    See conversion chart on this page.
    https://www.rsracing.com/tech-wheel.html
    OP, you want the 4.5" backspacing for your application.
  6. Nov 10, 2010 at 8:48 AM
    FixedTRD
    Will
    Alhambra, CA
    Sorry for the confusion but I was referring to this.
  7. Nov 10, 2010 at 9:31 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    I'm running a 17x8.5 with 4.75'' backspacing it's a little tighter than when I had 17x9 with 4.5'' backspacing but I don't have any problems.
