spindles vs coilover?
Discussion in 'Suspension' started by puddin67, Aug 17, 2012.
  1. Aug 17, 2012 at 9:42 AM
    puddin67
    puddin67 [OP] Well-Known Member
    Zach
    Savannah, GA
    04 PreRunner SR5
    Westin bull bar with blacked skid, 6000k xenon bulbs, 2 Almani 12" subs, 1600 w Boss amp, Kenwood head unit, AVS rain guards, removed mudflaps, UWS toolbox, 3/4 debadged, blacked grille emblem, blacked tail lights, sockmonkey 3rd brake light cover
    So apart from the actual amount of lift, what is the difference between a spindle lift vs new shocks and coilovers? :confused:
  2. Aug 17, 2012 at 9:47 AM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Spindle 2 wheel drive only. I think minimum lift is 4" and you replace your spindles and can keep factory coil-overs. I think you also retain the same stock ride for the most part. People that have spindles say its the best way. Also you will need a large rear lift to compensate for the high front lift.
    Coil-overs 0-3+ inches of lift might need UCA's loose stock ride comfort.
  3. Aug 17, 2012 at 10:50 AM
    puddin67
    Zach
    Savannah, GA
    04 PreRunner SR5
    So basically for a 2 wheel drive spindles is the way to go?
  4. Aug 17, 2012 at 10:53 AM
    puddin67
    Zach
    Savannah, GA
    04 PreRunner SR5
    Does it give any more travel?
  5. Aug 17, 2012 at 4:21 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    No, the suspension is still the same
    Spindles are the way to go if you want a lift on a 2wd, correct
  6. Aug 17, 2012 at 7:31 PM
    puddin67
    Zach
    Savannah, GA
    04 PreRunner SR5
    oaky cool, where can i get just a spindle lift? i know fabtech offers with two new front and two new rear shocks and an AAl, but what if i want just the spindle? im thinkin if i can get the spindle lift to do 4 inches up front, then i can go with a 2 in AAl and a 1 in shackle for a level ride...any suggestions? also, what would happen if i got the spindle and a larger coil up front, would it add lift in addition to the spindle?
  7. Aug 17, 2012 at 7:39 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    Not trying to jack this. I am also interested. How does it retain factory ride and all with 4 inches of lift? Thought over 3 inches of lift without a drop bracket lift you don't have any down travel
  8. Aug 17, 2012 at 7:45 PM
    black coma
    black coma Active Member
    edwin
    hesperia
    07 prerunner sr5
    None yet
    with the lift spindle all it does is lower the hub assembly down to gain the lift you will also widen the distance between the front wheels but only slightly. the uca and lca stay in the same place and the stock steering geometry is kept stock. you will still have the same amount of up and down travel as you did before putting the lift spindle on.
  9. Aug 17, 2012 at 7:57 PM
    sir1123
    Charleston
    Nice well are spindles only made for 5 lug first gens? Can't find any.
  10. Aug 17, 2012 at 8:13 PM
    black coma
    edwin
    hesperia
    07 prerunner sr5
    None yet
  11. Aug 17, 2012 at 8:27 PM
    sir1123
    Charleston
