spindles?
Discussion in 'Suspension' started by taco_man, Sep 13, 2009.
  1. Sep 13, 2009 at 7:36 PM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    what other suspension components do i need if i run spindles?
  2. Sep 13, 2009 at 7:37 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Just a lift for the rear unless you want a crazy lean! haha. But you can upgrade the shocks as well but you dont have to.
  3. Sep 13, 2009 at 7:38 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    The only thing you'll need is to lift the rear.
  4. Sep 13, 2009 at 7:43 PM
    taco_man
    Austin
    Houston
    09 texas edition
    right now im just running the basic toyota shocks, but there is a guy who wants to sell his shocks off his 2009 trd for 200. would yall upgrade to these??? and do a aal in the rear with 5100's?
  5. Sep 13, 2009 at 7:45 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Dont buy those. If you want to get some decent cheap shocks get the bilstein 5100's. You can get those all around if you would like. Just a single aal still might not be enough. How do you want it to sit? Like stock just higher? Front higher? Level?
  6. Sep 13, 2009 at 7:46 PM
    taco_man
    Austin
    Houston
    09 texas edition
    id like it to sit level. and how much harder is this to install compared to a normal lift
  7. Sep 13, 2009 at 7:47 PM
    Incognito
    VA
    Are they the ones that came on the truck, are or they the Bilstein 5100's?
    If they came off the truck from the factory, then no, I wouldn't upgrade. I'd get some Bilstein 5100's. For the AAL, I'd just go ahead and get a 3'' leaf pack from somewhere like All Pro or Alcan. With just the AAL back there, it'll be leaning like you have 10 bags of sand back in the bed.
  8. Sep 13, 2009 at 7:48 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Im not sure. I plan on getting some in the way future. If I remember some are bolt on and some weld on. You will need longer brake lines but the spindles should come with them. Total chaos makes 3.5" spindles but they are like $1350 and Camburg makes 4" and are about$1050
  9. Sep 13, 2009 at 7:49 PM
    Incognito
    VA
    When I get spindles, I'm going Camburg.
  10. Sep 13, 2009 at 7:50 PM
    taco_man
    Austin
    Houston
    09 texas edition
    with the 3 inch leaf pack am i going to have to worry bout sagging?? i put a lift on my friends 04 tacoma and a year later his rear is a lot lower compred to where we had it...
  11. Sep 13, 2009 at 7:51 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Depends on what you get. Some come scagged or something like that to prevent sagging. I bought mine used and it gave me 3". You shouldnt have to worry.
  12. Sep 13, 2009 at 8:02 PM
    taco_man
    Austin
    Houston
    09 texas edition
    wait okay. i go confused. i thought yall were talking about blocks in the rear. not a leaf pack. so what if i did a aal and block in the rear with the 5100s. would that level?
  13. Sep 13, 2009 at 8:04 PM
    Incognito
    VA
    That would, but it'll ride worse and you run the risk of axlewrap, which you definitely don't want. Blocks don't flex nearly as good either. I'd stay far away from them.
  14. Sep 13, 2009 at 8:09 PM
    taco_man
    Austin
    Houston
    09 texas edition
    how does it cause axle swap?
  15. Sep 13, 2009 at 8:14 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I cant explain it but aal and leaf packs are way better to lift the rear. And if you offroad you dont want blocks. But you can always try it and see if you like it. Get like a 2" aal and a 1" block. Then if you dont like it switch.
