Spiral cable changed, bag light still on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by diode, Aug 30, 2012.
  1. Aug 30, 2012 at 8:14 AM
    diode
    diode [OP] New Member
    Randy
    07 Tacoma
    Had my cable changed yesterday under warranty on my 07 Taco, 80k. The process took 3 hours. At 2.5 hours in, the service advisor notified me the hardware portion of the update was complete but installing the software was going slow. A half hour later the update was complete but the bag light was still on, "Would you like us to diagnose the issue?". No thank-you @ $95 an hour. Service advisor said if it just needed recalibrating then it would be done during diagnosis without prior approval from me.
    The light had been intermittent but now is full time.
    Anyone have a similar experience? I would expect "recalibrating" would be involved in the software update thet they "had trouble with".
  2. Aug 30, 2012 at 8:18 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    The light is either a result of the cable or throwing a code for something else with ABS. If they did the repair properly the light goes out unless you have another actual code in there. The system should be reset and lights will go off until system can throw a code later on if one exists.
