Spiral cable or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bikinaz, Jul 17, 2023.
  1. Jul 17, 2023 at 11:48 AM
    Bikinaz
    Bikinaz [OP] It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    A couple months ago my cruise control started acting weird. Resume wouldn't work sometimes, the green light lit but cruise wouldn't engage stuff like that. This got worse and soon became one day cruise works normal, the next day it won't. Now cruise control is completely dead.
    This is a 14 regular cab that had the cruise installed by the previous owner. The question is would you start with the OEM cruise stalk ($$) or go straight to the spiral cable ($$$?)
  2. Jul 17, 2023 at 11:53 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    If you have OEM cruise, you can find matching sticks cheap on Amazon. They may not last forever, but easy enough to check. I did it 3 years ago, easy. Of course, I'm going to need a re-replacement soonish....
    Bikinaz[QUOTED][OP] likes this.
  3. Jul 17, 2023 at 12:00 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    So based on the finicky operation of the cruise you feel it's the stalk?
    Oldie2007[QUOTED] likes this.
  4. Jul 17, 2023 at 12:01 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Does your horn work? Does the cruise light on the dash light up when you turn it on?
  5. Jul 17, 2023 at 12:01 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Yup.
  6. Jul 17, 2023 at 12:03 PM
    tak1313
    2013 Base 2WD
    Does your cruise light turn on at all when you activate it?
  7. Jul 17, 2023 at 12:09 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Not anymore.
  8. Jul 17, 2023 at 12:17 PM
    tak1313
    2013 Base 2WD
    If you don't want to hassle with the airbag right away, you can take resistance measurements from the S8 (if I recall) socket at the bottom of the steering column. Put a meter on it, and run the stalk through the different positions and see if you are getting the different resistance measurements.
    The cruise operates through one wire. The stalk sends different signals by changing the resistance coming across the one wire.
    If you're getting some, but not all, it's likely the stalk. If you're not getting anything, it could either be the clock spring or that stalk and you will have to take the step of taking the airbag off and measuring to see if stalk is correctly signalling the various resistance. If so, you can check for clock spring continuity from behind the steering wheel to the S8 socket.
    The horn working but cruise not even activating lends more to a bad stalk, but when I installed my cruise (I have a base 2013) my horn was working fine, but cruise didn't work (new stalk). I measured for continuity from input to output, and determined it was the specific trace for the cruise.
    Pulling the clock spring and taking it apart, I found a TINY wear spot on the spring ONLY on the trace for the cruise. The other traces were worn in the same general area, so eventually they all would have worn through.
    Other possibilities are:
    If you have a manual, it could also be a faulty switch/circuit
    If you are getting the resistance readings off S8 correctly, it could be the ONE wire/wiring going to the ECU from the steering column
    TireFire likes this.
  9. Jul 17, 2023 at 12:45 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Assuming my first stalk was OE, which I presume, that's how it died. Bit by bit, affecting nothing else. My replacement has slowly started misbehaving, Turing cruise OFF when I try to set. Now and then, it doesn't like to cancel. But they don't cost much, so I'll do it again when that's my major worry!
  10. Jul 17, 2023 at 2:51 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Does cruise control work if you turn the wheel stop to stop? If so, it’s the spiral cable
    Bikinaz[OP] likes this.
  11. Jul 17, 2023 at 7:06 PM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    Not sure if mine was exact like yours. My cruise never worked from the time I bought the truck. My problem ended up being the small cable between the spiral cable and the switch. Part number was 84633-04020. My switch was fine. Good Luck.
  12. Jul 17, 2023 at 7:10 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Spiral cable. Purchase from Dealer using your VIN. Take that back, missed the part about the previous owner's installation. I'll leave it to the experts.
  13. Jul 18, 2023 at 6:51 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    No it chooses when it wants to work. Ironically, it worked again for a trip yesterday. First time in probably a month or so.
